open port
1 TopicPort Forwarding issues
Wan IP address is 172.103.xxx.xx 1. Did enable "remote management" on port 8843 When I check if the port is open, yes it is. When I go to 172.103.xxx.xx:8843 from my home network I do get to the routers admin page. So its all fine, but when I go the same address from outside, the port is still shown as open but Im getting an error "The site cannot be reached" 2. I did enable port forwarding for port 1001 (internal and external), but I cannot reach this url from outside and when I test port it says that port is closed. Why is it closed when I did set port forwarding? What else I should do?Solved8.1KViews0likes27Comments
