orbi RBK50
2 TopicsConfusing Orbi RBR50/RBS50 versions
Hello, I have just checked for firmware updates on my Orbi RBK50, and saw that there is a new (??) version: 2.0.1.4 Is this correct? Someone messed up the versions? Or the site was incorrectly updated? The previous version was: 2.1.2.18 (!!!) If this is a major release the correct version would be 2.1.3.0 or anything with 2.1.x.x If there is someone from Netgear watching the community posts, please look at this. Best Regards, RicardoSolvedBest WiFi Solution for unique long/tall home.
I just moved into a new home and I am trying to get WiFi coverage in all spots. It's a very unique skinny/tall home with 2,700+ sq feet of space. There are 4 floors including the basement with the living spaces at opposite ends of each floor connected by a long hallway (home is 60FT long front-to-back with 9+ ceilings on each floor). I set-up Verizon Gigabit service and currently have the Verizon Gigabit router located in the living room (front room) of first floor and it reaches all areas, but am looking to replace/augment as the performance is slower in the back rooms of floors 2 & 3 (office + master BR). I have already have already installed 3 nest thermostats, 2 Alexas and plan to add more smart devices (e.g. Cameras), so connectivity is essential. Additionally the home is fully pre-wired for ethernet in every room with multiple jacks with the main box in the basement, so I could potentially connect routers directly to the ethernet jacks in the rooms if I added a switch in the main box in the basement. Though I prefer to do something easier with plug and play. I'm looking for a solution that will offer the same network name (mesh-experience) across all 4 floors front-back of the home with the fastest possible wifi. I have compared Orbi, Velop, Google, Eero etc. and it seems that Orbi/Velop are the two that would be best. I would appreciate some help from the community! If Orbi, which system is best (RBK50, RBK53)?2KViews0likes2Comments
