orbi android
5 TopicsSmart Parental Controls Help and Information FAQ
For users needing help and information regarding Smart Parental Controls: NETGEAR Smart Parental Controls Managing the family’s internet time has never been easier. WiFi with built-in Smart Parental Controls keeps your family connected and protected for complete peace of mind. https://www.netgear.com/home/services/smart-parental-controls/ What are the features of NETGEAR Smart Parental Controls and Smart Parental Controls Premium? https://kb.netgear.com/000062103/What-are-the-features-of-NETGEAR-Smart-Parental-Controls-and-Smart-Parental-Controls-Premium Which NG routers support Smart Parental Controls: https://kb.netgear.com/000064166/Which-products-support-NETGEAR-Smart-Parental-Controls? How do I set up and install NETGEAR Smart Parental Controls? https://kb.netgear.com/000062109/How-do-I-set-up-and-install-NETGEAR-Smart-Parental-Controls How do I start a subscription for NETGEAR Smart Parental Controls Premium? https://kb.netgear.com/000062167/How-do-I-start-a-subscription-for-NETGEAR-Smart-Parental-Controls-Premium Why can’t I see the NETGEAR Smart Parental Controls tile in the Orbi or Nighthawk app after upgrading to the latest firmware? https://kb.netgear.com/000062988/Why-can-t-I-see-the-NETGEAR-Smart-Parental-Controls-tile-in-the-Orbi-or-Nighthawk-app-after-upgrading-to-the-latest-firmware OpenDNS Notice: https://community.netgear.com/t5/Nighthawk-WiFi-Routers/NOTICE-Live-Parental-Control-Service-based-on-OpenDNS-will-no/m-p/2071958#M186847 If you cannot find the NETGEAR Smart Parental Control tile in the Orbi App, please make sure that the following conditions are met: 1. You are in a country where SPC is available. What countries is NETGEAR Smart Parental Controls available in? 2. Your NETGEAR single sign-on (SSO) account is registered to a country where SPC is available in your MyNETGEAR account profile settings. https://kb.netgear.com/000063796/What-countries-is-NETGEAR-Smart-Parental-Controls-available-in?language=en_US 3. The NETGEAR SSO account that you use to log in to the Orbi app is the same account that your router is registered to. 4. Your router isn’t in AP (access point) mode. How do I cancel my NETGEAR Smart Parental Controls subscription? https://kb.netgear.com/000064285/How-do-I-cancel-my-NETGEAR-Smart-Parental-Controls-subscription Help with Subscription Services: https://kb.netgear.com/000063635/How-do-I-get-help-with-my-NETGEAR-subscription-service To get a hold of support for subscriptions services like Armor/Circle/Smart Parental Controls, click on "MyNetgear" in a web browser: https://www.netgear.com/support/# To get a hold of support for subscriptions services like Armor/Circle, click on "MyNetgear" at the top. Register an account (or login) and then the device. From there you can start the support process. Click on: My Support---->Contact Support---->Get help with my subscription service For additional help and information regarding Smart Parental Controls, please contact NetGear support: https://my.netgear.com/support/contact.aspx Thank you.SPC-ACT-FAIL Error
Hello, I have a premium subscription of SPS which started on May 5, 2025 and is active till May 5, 2026. It used work fine until a few weeks back. However, for the last few weeks whenever I open the app it asks me to set up SPC and after sometime it shows the SPC-ACT-FAIL Error screen. And SPC are no longer working and not applying any filters that I had set and which were previously working. Can someone help me with how to resolve this? I tried uninstalling and re-installing the app but it made no difference. Thanks, GeorgeOrbi 970 SPC Issues
I recently purchased the 970 3 pack. The connectivity is amazing no issues with dead zones or dropping connection. The parental controls are extremely delayed or sometimes not taking effect unless I reboot. If i pause a device, the device will stay connected for a while unless i do a reboot. If they're playing a game or in a voice call the connection will continue until they end or leave that call/game. Is this normal use case or is something wrong?Time limit on non listed apps
Hi, My son is watching the dudeperfect app on a firestick and I would like to set and hour limit. Since the app is not listed with all the other apps such as instagram to limit can I manually add the app? I did notice the under usage -> categories-> Blogs & Personal Sites it has dudeperfectplus and a time pf and hour and 15 minutes. I can limit that categorie but was wondering if easier way as there other apps like kiddio tv and others that are hard to find to limit. ThanksI have been using Parental Controls daily for years, and yesterday it was no longer there
I'm experiencing the same problem. I have been using Parental Controls daily for years, and yesterday it was no longer there. Still not there today. Android App 2.45.1.4740 Firmware v2.7.5.6 Modedl RBR50 The app doesn't have an option for 'My Subscriptions' nor does it have an 'Add Ons'. I checked the routerlogin and there is no option for 'Parental Controls'. Something has changed.
