packet loss
1 TopicHalf of Pings Drop over IPSec Tunnel
Hi there! Pull hairs over here, I have a IPSec Tunnel between two pFsense Firewalls. Pings to both Gateways without issue, pings to PCs on Remote LAN succeed without issue. When pinging the ReadyNAS on the Remote Network, half of the pings fail while the other half succeed. At this time, I cannot access the ReadyNAS on the Remote Network from the Main Network over VPN. There is no issue pining the ReadyNAS when on the same local subnet. Local Nework: 192.168.10.x Remote LAN: 192.168.30.x (c) 2015 Microsoft Corporation. All rights reserved. C:\WINDOWS\system32>ping 192.168.30.50 Pinging 192.168.30.50 with 32 bytes of data Request timed out. Reply from 192.168.30.50: bytes=32 time=147ms TTL=62 Request timed out. Reply from 192.168.30.50: bytes=32 time=133ms TTL=62 Ping statistics for 192.168.30.50: Packets: Sent = 4, Received = 2, Lost = 2 (50% loss), Approximate round trip times in milli-seconds: Minimum = 133ms, Maximum = 147ms, Average = 140ms C:\WINDOWS\system32>3.7KViews0likes2Comments
