power budget
1 TopicTotal Power Budget 83W but total load maybe 100W at power-on
Hi all, we plan to use Netgear GS305EPP for a new project. This has 4 PoE ports with a maximum power budget of 83W. All 4 PoE ports will be connected to a PoE device that can use up to 25.5W but average usage is only 10W or so. So possible maximum at start-up or power-on is 102W with average total power usage of 40W. Is our use case OK for GS305EPP?
