power down
2 TopicsRN10400 Won't Shut Down
My NAS won't complete shut down when selected from the GUI or initiated by the power button on the unit. It hangs on the "Shutting Down Goodbye" screen with only the power indicator blinking at approximately a 1 Hz rate. Othe LEDs are on solid. Only the WoL function is enabled. Disk Spin Down and Power Timer are both off. And the Log contains all GREEN indications. Tried to manually re-install the FW from the downloaded ZIP file, but of course that did not complete because it could not shut down to restart. Did an OS Reinstall from the Boot Menu. No luck on any of these efforts. When unit hangs at Shut Down, I have to pull the DC plug from the rear and then reinsert it. Unit operates fine otherwise. Any suggestions would be greatly appreciated!! Running FW 6.5.1. One application loaded: PLEX. 1.77TB free out of 1.81TBSolved4.7KViews0likes9Comments6.4.1 RC1 wants to wake
This firmware wakes my 102 after it powers down. It's set to power down at 11 PM, which it does but immediately powers up again. This repeats at midnight but stays awake for 18 mins. After that if stays off until 6AM when it powers up as it should. The only 'activity' that happens in these unwanted periods of power on is AV updates.2.8KViews0likes6Comments
