pro wifi
2 TopicsMounting Compatibility
Hello, I would like to replace a Netgear Insight Managed WLAN Access Point (WAX-620) with a more modern one (WBE-710 or WBE-750). The current one is mounted on the ceiling. Are the models mentioned compatible with the ceiling mount of the WAX-620?Solved343Views0likes4Comments
