public raidiator 4.1.x beta
1 TopicFailed Disk?
Hi All, I wonder if you can help please. I am running a ReadyNas NV+ with RAIDator 4.1.14, the unit has 1gb of RAM and 4 hard drives eaching being 2tb. They form i large RAID drive. The unit has been running fine for a long time until a power down, and since the unit does not come back up. In order to try to get the unit back up and running I have: - completed a Memory Test - Reinstalled the OS - Booted from USB and reloaded the firmware 4.1.14 Currenty the unit boots and gets stuck on a Quota Check at 16.2% - it seems to just hang and stop. At one point it was getting to 62%ish and hanging. I've now done a boot without file system check, and Disk 1 seems to be re-syncing. My current issues is that the logs show: Access to the disk on channel (??) is producing I/O errors. Although the array is still redundant, please replace this drive as soon as possible, as it is likely to fail soon. Any ideas on the next steps?? I have spare disks at the ready. Many Thanks James3.5KViews0likes5Comments
