quota scan
1 TopicReadyNAS NV+ Frozen at Quota Check
Greetings! I came home to find that my ReadyNAS NV+ (which is at least five years old) had frozen and was invisible to RAIDar. After being turned off and on again, the NV+ started the quota check. But it froze at 25.4%. I tried again, and this time it froze at 15.1%. I've read some other threads here, and it looks like this can happen when one of the drives starts to fail. However, I didn't receive any warnings or drive errors, and I don't know which drive is the problem drive (or if there even is a problem). I have two 1 TB drives in a simple RAID 1 configuration. So, here are my questions: 1. Does the frozen quota check mean that I definitely have a problem with one of the hard drives? 2. If the answer to 1 is yes, how can I tell which hard drive is the wonky one? I do have a backup by USB, so if I have to replace both drives I'll survive, but of course I'd rather not do that if I can avoid it. I've read through three or four threads here, but I'm still not sure how I should proceed. I know that one option is to go into the boot menu and skip the volume check, but the NetGear website insists that this should be done only after consultation with NetGear support. So, I'd be grateful for any advice or suggestions. Thanks! MatthewSolved6.5KViews0likes6Comments
