r7000
127 TopicsR7000 Nighthawk - Expanding to a remote workshop
I've had a AC1900 R7000 Nighthawk operating in my house for many years and it has provided good service to connect devices like my MacBook Pro Laptops and iPad. I recently built a stand alone Metal Pole Barn style workshop about 200' away and when the doors are closed can't pick up the house WIFI signal. During construction we buried a Cat 5 cable between the buildings with the idea of putting a 'Remote" device in that shop, wired to the Nighthawk in the house, to allow a better connection of my user devices. I'm ready to make the cable connections, but need to know what kind of device would be good to put on the end of the Cat 5 cable, to allow a wireless connection, when I have my laptop out in the workshop. What are some small, compatible boxes that would do the job interfacing with my Nighthawk R7000?63Views0likes4CommentsGuys this problem is that the Netgear Router is blocking ports needed by comcast email
Guys this problem is that the Netgear Router is blocking ports needed by comcast email. When i connect to my Router from Cox I have no issues but when I connect to the Mesh from NEtGear is doesn't work. Can somebody explain how to free up those ports to allow this to work like my Cox router.R7000 AC1900 Factory Reset Itself After Power Outage
Our AC1900 has completely reset itself after a power outage last night. Auto updates is disabled but I have kept it up to date manually. Current version is V1.0.12.216_10.2.122 The router is 7 years old, bought new. Is this behavior something that should be expected from this point on until we replace the unit?Netgear R7000
i was getting buffering - checked the modum and that was good- unplugged the router - finally reset it - but when i try to connect the router to my computer with the ethenet cord the routerlogin - the page never loads not sure where to go from here - purchased in 2021 so its not that old and its been a great router with a good range to reach my back field where i monitor bluebirds with a blink camera121Views0likes3Commentscannot access my nighthawk router after changing xfinity password
I changed my wifi password with my Xfinity modem today. I am using my nighthawk router as an extender. I thought I had to update the password on my nighthawk to this new one though I am not sure this is necessary . I went to login to my nighthawk on the app but I get a " wifi not detected" message. I then tried to login on my pc using routerlogin.net and also the 192.168.0.1 but neither worked. First of all do I even need to do anything to my router if I simply changed my Xfinity wifi password? If yes, how can I access the admin panel on my router? Thanks for any help.149Views0likes2CommentsInternet connection Interruption
Over the past couple of weeks I have noticed internet connection interruptions. I'm trying to track down the source of the interruptions. I started with the Netgear Nighthawk R7000 logs and found out that the logs have a very limited length and do not appear to cover enough time to allow me to look back in time more than 1 hour. How can I have a longer log? Is there something else I should be looking at to eliminate the router as the source of the interruptions?126Views0likes6Commentsr7000 router only shows two lefthand lights
We lost internet this morning. Verizon Fios says that the internet is all good on their end, so it potentially is a problem with our R7000 router. (https://www.netgear.com/support/product/r7000/) Only the two left lights are showing and I dont think that's right. Anyone know what I can to do fix it? Do we need a new router??75Views0likes2Comments
