r8000
30 TopicsR8000 380Mbs max download unless manually set Internet Bandwidth, but reverts to slow after reboot
Further to Nighthawk X6 R8000 not getting gigabit speeds | NETGEAR Communities - "https://community.netgear.com/discussions/home-wifi-routers-nighthawk/nighthawk-x6-r8000-not-getting-gigabit-speeds/1859023" . Since moving to fiber to the premises, I have 500/50 internet connection, but I can't get these speeds unless I manually: 1. enable QOS 2. disable QOS 3. "I want to define my Internet Bandwidth": <Set to your ISP's connection Download and Upload settings that you are paying for> After my router is rebooted though it seems to revert back to slow speeds. Netgear can you fix this for us please?Nighthawk X6 AC3200 model R8000 no lights
Howdy. For years I’ve had this router (Nighthawk X6 AC3200 model R8000 no lights ), and periodically it would stop allowing me to join the WiFi. My cure for this is to unplug it and plug it back in, and after it reboots all is well again. Before I unplug it, it has a bunch of lights on and looks like it’s functioning normally. today I had the first part of the problem, meaning I couldn’t get on the wifi — but after I unplugged it and the lights went out, they never came back on. I’ve plugged it and replugged it, I let it sit unplugged more than an hour to make sure I’d let it “sit” long enough, I’ve tried the power switch… but all lights remain off no matter what I’ve tried. anything I can do, or is it just dead? thanks.Solved178Views0likes7CommentsMy r8000 will not let me put in a login name
My r8000 will not let me put in a login name. That field will not take focus. I reset the box. It took 45 seconds before the power light would flash. I input the default so there would be no confusion. I filled in the questions but on the last answer, the page would not progress, it just hung there. After a while, the page turned to checking for firmware update. After several minutes, it stated it was updated. It took me back to the page for inputting the login and password. It would not let me select questions without inputting a login and pswrd. But it would not get past the last question and then start over again with firmware update. I have tried this directly connecting to the router with Ethernet from PC and with genie on my cell. When I attempt to access the router with my cell, it states I need to go to a website to get the app. I go to that site and it says I have to go to the site to get the web app. I am only getting circles. How might I break out of this?63Views0likes1CommentI need to forward multiple TCP ports to a single internal port on a single host
This is an older thread, but I want to do the same thing. I need to forward multiple TCP ports to a single internal port on a single host. This router won't let me. For example: External (TCP ports 8080, 8100, 8200) -> R8000 -> Internal Host (TCP port 443). This seems like a basic router feature to me. It should also pass through the FQDN that it arrives with. The reason for this is having an NGINX Proxy Gateway that can then send the correct traffic to the correct Docker containers. Would this be possible with the Firewall instead maybe?Region change?
I bought R8000 from US during my travel and i want to use it within EU. Region setting can't be changed from admin interface and wireless performance is sluggish because of the low power compared to my home country. Is there any way to change region of this router other then US?Solved124KViews0likes22CommentsNetGet NightHawk X6 AC3200 R8000 - OpenVPN - MD5
Good night, I have a NetGear NightHawk X6 AC3200 R8000 with the firmware 1.0.4.12 installed, the lastest, and I can confirm that no change has been made to the VPN certificate, even though this was known at least since January 2018 when a NetGear Moderator indicated that NetGear was going to support the new certificate before OpenVPN stops supporting the MD5 certificate (April 2018). Here is the post I refer to: https://community.netgear.com/t5/Nighthawk-WiFi-Routers/R8300-Support-for-MD5-Certificates-with-Built-In-VPN/m-p/1496268#M81267 I insist to NetGear to solve this problem in the following days and fulfil with their word. This is a complete lack of respect to their clients and users, and I would not stand at all this situation. If necesary, I will take al necesary means to make sure that this problem is finaly resolved. Thanks in advance. Yours sincerely, Buzzetti MartínSolved3.9KViews1like2CommentsR8000 QOS Performance Optimization Database Not Updating
Hello, Whenever I try to update the Performance Optimization Database in the QoS, it says that it hasn't been updated, despite it from the end of 2015 (version 1.80,1.0.26 from 12/28/2015). My router has the most recent firmware update available, as shown in the picture. I had it set to automatically update before, so I didn't think about it too much. I updated my parents' R7000 to a newer firmware, and after I checked their QoS settings. They already had a newer version on the database, and when I hit the update button, their router was offered and even newer version (unfortunately, I don't have that version date or number notated). I started to research my issue when I came accross another thread about the same thing ( https://community.netgear.com/t5/Nighthawk-WiFi-Routers/R8000-QOS-how-do-you-set-new-applications/m-p/1244609#M51975 ) and the official response from ElaineM was that "We will be providing regular updates on the QoS database on our routers with Dynamic QoS" and "We will inform the community if it becomes available" on April 6th. I can't find any more recent info on this problem. Is the R8000 getting any more QoS Performance Optimization Database updates? Why is it currently not pulling down the current updates? When can we expect a solution to this issue? I love this router to an unreasonable degree (it helped me fix most of my network issues, has amazing Wi-Fi range, and very rarely needs any tinkering or reboots if any issues do arise), and would like to keep all aspects of it updated. Thank you for your help.Solved20KViews4likes30CommentsR8000 USB 3.0 not working after updating to Firmware 1.0.3.54
My readyshare drive (external hard drive) plugged into the USB 3.0 port was inaccessible after updating my R8000 firmware to the latest verions 1.0.3.54. The drive wasn't being recognized by the router, by checking the web interface. There was no issue with the drive when plugged into the USB 2.0 port or my laptop. I checked the USB 3.0 port with a couple other external hard drives and usb pen drives. Again with the same results, not recognized in the USB 3.0 port, but working fine in the USB 2.0 port. Resetting back to factory settings didn't help. From there I rolled back to firmware version 1.0.3.48, and then like magic the drive in the USB 3.0 port was being recognized. There seems to be several posts regarding issues with the USB 3.0 port, but the only solutions being offered by support is to try a factory reset. I was very close to contacting support for a hardware replacement since my warranty is close to the end of the one year. My issue isn't hardware, it's with the firmware. I hope there is work being done resolve the issue in a firmware update.Solved2.9KViews0likes2CommentsAC3200, R8000 New Power supply? What size pin?
I can't seem to figure out what original power supply came with this router. Got it from a friend less than a year old but the power cord was lost in a few moves. I purchased a universal howerver that did not solve the issue, the actual plug into the back of the router is incorrect. Is it a 6.5mm jack? I can't tell! I at least got that it needs 19v and 3.16ampsSolved5.1KViews0likes2CommentsOutbound Mail Blocked
R8000 Nighthawk Firmware Version: V1.0.3.48_1.1.33 or 1.0.3.54_1.1.37 (went back a version to see if the latter broke anything) I receive emails all day long but cannot send email through the router. I've bypassed the router by connecting PC directly to modem and no problems. I've even used another older router and don't have any issues. PC is using Outlook 2010 with several email addresses, both POP3 and IMAP. Even wife's Iphone can't send emails. Depending on device, we get various messages: Iphone gives a Relaying Error while PC gets SPAM Error: IMAP Account gets: "Diagnostic-Code: smtp; 554 5.7.1 Spam detected by content scanner. Message rejected." POP3 Account gets: "550 5.7.1 Spam detected by content scanner. Message rejected." Checked with ISP and I'm not blacklisted. ISP Tech support keeps asking me to mess with Outlook settings. But since I can send without R8000 in the mix, I'm hesitant to fool around with them. Though I have them memorized by now. Network is set up for home use only and not running any servers. Router is configured to not block any sites or services. Port Triggering & Forwarding enabled on 587. Any suggestions?Solved18KViews1like2Comments
