recycle bin
2 TopicsWhere did my Recycle Bin go?
I accidently deleted a file and went looking for the Recycle Bin to restore it. I am pretty sure I've seen a Recycle Bin associated with my User account, but it was nowhere to be found. I have the Recycle Bin enabled in the Security > User Group > Preferences, but have no idea where it is. Model: RNRNV2-S2-0000 Processor: IT3107 Sparc RAIDiator 4.1.16Solved7.6KViews0likes5CommentsAuto clean "Recycle bin" on OS6.6 ?
I have looked though this post: https://community.netgear.com/t5/Using-your-ReadyNAS/Can-Recycle-Bin-be-enabled-for-CIFS-and-OS-6-1-2-on-a-314/td-p/856707 And I have successfully enabled the "recycle bin" on my NAS, it works fine excpet I have to empty it manually. I have crated a 'clean_recycle_bins' script and a 'recycle.conf' file according to the post, but when I try to run this scrip using " /frontview/bin/clean_recycle_bins start", I get this : "Can't locate Frontview.pm in @INC (you may need to install the Frontview module) (@INC contains: /frontview/lib /etc/perl /usr/local/lib/arm-linux-gnueabi/perl/5.20.2 /usr/local/share/perl/5.20.2 /usr/lib/arm-linux-gnueabi/perl5/5.20 /usr/share/perl5 /usr/lib/arm-linux-gnueabi/perl/5.20 /usr/share/perl/5.20 /usr/local/lib/site_perl .) at /frontview/bin/clean_recycle_bins line 8. BEGIN failed--compilation aborted at /frontview/bin/clean_recycle_bins line 8." So I guesee I am missing some frontview module files right? Where can I get them?Solved7.6KViews0likes18Comments
