remote desktop connection
1 TopicCan you Remote Desktop to Windows Server via Orbi RBR50 router?
Dear Community, I would be extremely grateful if a member could please answer this question and if it is possible please advise how to achieve. I have been struggling for two weeks and exhausted every avenue. I have a windows Server 2012 R2 that Id like to place on my home network and access away from home. I use an Orbi RBR50 with one additional satellite. The server is configured correctly for Remote Desktop as it was working when in a business location previously. I can also connect to the server using RDC locally through my LAN. I have enabled remote access in the advanced Orbi settings and configured port forwarding on port 3389 to the server on a static LAN address. I can see ports 80 and 3389 are open through a web checker and can ping the the WAN IP address revieving 4 packers back. However, when trying to RDC away from home RDC is unable to connect to the server login screen? Any ideas please? Shacksie70
