router not working
1 TopicWNDR3300v1 - Router not working
Our wireless connection went out, so I made sure everything was connected and restarted the router. This did not fix the connection. Then I check with our provider to see if our Internet connection was good and it was. I discovered that even when I plugged my computer directly into the router I could not get a connection. Is there a way to fix the router or do I need to get a new one?Solved
