router not working
1 TopicRBKR50
I recently replaced my cable modem and now I cannot get the ORBI to work. I try to trun off the router then plugin the satelite, wait for the satelite to flash magenta (which is does eventually). The problem is that the router starts flashing magenta and the satelite ring lite goes off. Ideas? As an aside I don't know how to access the configuration of the ORBI. I know when I set it up I setup an admin login.
