separate rooms
2 TopicsHardwire the EX7000 instead of wirelessly connecting to the router?
I’m going to try my best to explain my current situation as best as possible since I’m not entirely tech savvy or literate. My current situation is that there are devices that need to be hardwired but the devices are located in separate rooms. One device in my room and one in my brother’s. Now I know that I can use the EX7000 to wirelessly connect to my router and just use the Ethernet ports but doing that cuts down on download speeds. So I was wondering if I can use the Ethernet port in my room and plug the extender into that so I won’t have to wirelessly connect to the router? The current set up is that we have Frontier FiOS and the ONT box is located in our garage. Not sure what that means but the employee from BestBuy said it acts as the modem so that all the Ethernet ports our house can support a router without the need of an actual modem. So currently, all we currently have the Nighthawk X6 plugged into the Ethernet port in my brother’s room and is producing a Wifi signal with internet. We now both have desktops that have no Wifi adapters. So in order to use the internet on our computer we need to be wired. We used to share a room so it was never a problem since the router was in our room but now that we have our own rooms, he kept the router while I have no possible way of accessing internet via wired connection. Since we both game, we prefer a wired connection overall for the best performance. Hence the reason why we never purchased a Wifi adapter for our PC. While trying to look up a solution for my problem, I was constantly seeing answers like using the EX7000 as an access point. However, instructions say to plug it in to a router, which defeats my purpose of buying the extender in the first place since the extender would need to be located in my brother’s room. So long story short, can I hardwire the EX7000 using the Ethernet port in my room so that it can provide internet to my devices that need to be hardwired into the extender?7.2KViews0likes4CommentsSetting up EX7000 access point without wiring it to the router?
I’m not too tech savvy but from what I read you set the EX7000 up as an access point and connect it to the router using the Ethernet ports. However that’s not what I want exactly. I was wondering if I can connect the extender to the CAT6/Ethernet port(not sure what the correct name of port on the wall is called) on the wall in my room upstairs instead of hardwiring it to the router. The router is downstairs in my brother’s room. Our routers connect to the internet via CAT6 ports instead of coax since the ONT box in our garage acts as a modem (according to the Best Buy employees I’ve talked to). So instead of having a modem connected via coax and a router connected to the modem, we just plug in the router with out the need of a modem device. So I was hoping I could just do the same with the extender and not it connect to the router wirelessly or have it hardwired to the router itself.998Views0likes1Comment
