slow speed
2 TopicsWNDR4300V2 slow in bridge mode with VDSL?
I've had a number of WNDR type routers (3400, 3400V4 and now 4300V2) and have worked well with my Cable modem (30M Down/5M Up). Recently I've switched to DSL and have upgrade connectivity to 50M Down/10M Up. When connected with both ISP provided Modem/router or a Smart RG 505 Modem/router I've been easily able to obtain these speeds with both WiFi and wired connections to the router. All works normally as expected. I want to use my Netgear routers as my DHCP/Gateway and have configured the modem in Bridge mode. I let the router handle the PPPoE login and things seem to work fine EXCEPT speed drops to max 27-28M Down/ 10M Up (both wired and wireless). I've been pulling my hair out over this. MTU is set correctly (checked with Ping and verified with ISP). NAT/Firewall turned off on bridge. I've even tried both modems with almost exactly the same results. Thinking it was a problem between the modem and router negotiating bridge setup I've set the modem up as the gateway and setup a DMZ host to point to the Netgear router (and my LAN behind it). Router is still DHCP server for my LAN and the router has a static "WAN" address on the same subnet as the LAN on the modem. Everything works great and I can login and verify both pieces of hardware. No double NAT issues and UPnP works fine. AGAIN the speed drops to 27-29Mbps. Too slow. I have also taken an old TPLink router and replaced my Netgear router as the Gateway/DHCP server/router and speeds are back up to 50M Down/ 10M Up in both bridge mode and as the DMZ target. So this really seems to point to the Netgear modem as the bottle neck. Any advice? I searched a bit and found a few similar posts but no resolution. Most suggestions were wrt MTU (which I've played with and verified with the other modem/router) or using it as a DMZ target which doesn't seem to increase my speed. Am I hitting the limit of the WNDR4300? It is a relatively recent router (only a couple of years old) so I expect it could handle 50Mbps?? Any help or advice is greatly appreciated. Thanks in advance.Solved6.9KViews0likes6CommentsR6400 Networking speeds
good morning all, i have a R6400 router installed in my home and i seem to be having issues on one of my har wire lines i have ran, to note i have ran Cat 5e thoughout my whole house, currently i have about 200Mbps speeds from my modem using Comcast as my ISP, i have my descktop hard wired to router, i have another line plugged into the router that runs to master bedroom (nothing plugged into it on that end) another one from the router to my living room where that line goes into a gigabit switch (in my gigabit switch i have a PS4,a Android TV box, surround sound reciever and tv) and the last port on the router goes down to another switch on my desk that goes to my NAS drive and another bedroom in the house (nothing connected in room) Ok so on my desktop PC im getting about 190 to 207 Mbps when i run a test, no big deal its perfect but when i try to run a speed test on anything in my living room i cant seem to get over 20Mbps, so i tried taking the line out of the gigabit switch and bypassing it strait into my laptop and again not more than 20Mbps now note i went back to my office where the router is and i took the cable that goes to my living room and went directly to my modem with it went back to laptop to run test again and now i get just over 100Mbps, so seems like my Cat 5e cable is good and that the router seems to be limiting my speeds somehow, can anyone else help with this issue? what could possibly be the issue here? sorry for all of the back and fourth stuff but i was trying to give as much description as i could with my systemSolved
