slow wifi
1 TopicNetgear PR2000 Trek N300 - as range extender: WiFi VERY slow / wired connection fast
I'm using my Netgear PR2000 Trek N300 as a range extender and when I connect to the LAN-only (yellow) port as wired connection with my laptop I get speeds of ~10Mb, however when I connect via wifi speeds are only about 0.5 to 1.5Mb ... I have tested the wifi speed across two laptops and an iPhone and all three are slow via wifi, so I know it is not the receving computer that is the issue I am using channel 11 on the PR2000 and the pull-down menu is gray-ed out so I am not able to try using a different broadcast channel.... I have latest firmware in the device xxx.14 Any help appreciated!Solved5.4KViews0likes8Comments
