spec sheets
1 TopicNighthawk x6s AC3000 compare to Nighthawk x8 AC5000
I am trying to decide which of these two routers are superior technically. They seem almost identical except the x6s says it has 6, external, high performance, amplified antennae, and the x8 says it has 4 active antenae. What does that mean. 2 desktops with AC connections, one we use for streaming to the TV which also has a ROKU device connected to a USB port 3 smartphones 5 Ghz 3 tablets 5 Ghz 2 laptops 5 Ghz and spikes to include, 4 iphones 2 ipads Speeds and feeds as follows but some of the tech talk leaves me wondering the x6s doesn't mention the DLNA server or the Dynamic QoS. Has it been replaced with other tech or jargon and what does it really represent in value Otherwise flash memory is 128, 512 RAM x6s processor 1.8 Ghz x8 processor 1.4Ghz data rate of the x6s is supposed to peak at 1300MBps at 5Ghz data rate of the x8 is supposed to peak at 2166MBps at 5 Ghz Beam forming for both x6s has link Agregate for faster file transfer x8 has Ready Share Vault for automatic backup All input appreciated.Solved6.1KViews0likes2Comments
