spin-down
1 TopicSince Google Drive is enable, Disk spin-down does not work anymore
Hello, Since Google Drive sync is enabled on my readynas (RN314), the spin-down does not work anymore. After disable the sync, the spin-down is working again Did you experiment that ? the problem seems the same with dropbox sync. Thanks for your help Below some logs: google-drive.log -- Logs begin at Sat 2017-07-29 04:43:16 CEST, end at Sat 2017-09-16 10:19:55 CEST. -- Aug 24 21:33:15 READYNAS ng-csd[13398]: Reset the cache. SQL Statement invalid: SQL error or missing database: no such table: settings Aug 24 21:33:15 READYNAS ng-csd[13398]: W0824 21:33:15.702988 13398 FSCache.cpp:78] Reset the cache. SQL Statement invalid: SQL error or missing database: no such table: settings Aug 24 21:34:11 READYNAS ng-csd[13398]: Failed to get resource by parent id and name. parentId = 1RfZ5qgh1Jd0MRqnLVjMP2DKBpcl_YcsYqG8nGXoO2bY, name = download_20150412_204649.jpeg. Extraction error: value already extracted Aug 24 21:34:11 READYNAS ng-csd[13398]: E0824 21:34:11.493209 13398 FSCache.cpp:254] Failed to get resource by parent id and name. parentId = 1RfZ5qgh1Jd0MRqnLVjMP2DKBpcl_YcsYqG8nGXoO2bY, name = download_20150412_204649.jpeg. Extraction error: value already extracted Aug 24 21:34:11 READYNAS ng-csd[13398]: Failed to fetch node! DATABASE_EXCEPTION: Extraction error: value already extracted Aug 24 21:34:11 READYNAS ng-csd[13398]: E0824 21:34:11.495277 13398 GoogleDriveFS.cpp:185] Failed to fetch node! DATABASE_EXCEPTION: Extraction error: value already extracted Aug 24 21:34:15 READYNAS ng-csd[13398]: Failed to get resource by parent id and name. parentId = 1RfZ5qgh1Jd0MRqnLVjMP2DKBpcl_YcsYqG8nGXoO2bY, name = lille.jpg. Extraction error: value already extracted Aug 24 21:34:15 READYNAS ng-csd[13398]: E0824 21:34:15.760298 13398 FSCache.cpp:254] Failed to get resource by parent id and name. parentId = 1RfZ5qgh1Jd0MRqnLVjMP2DKBpcl_YcsYqG8nGXoO2bY, name = lille.jpg. Extraction error: value already extracted Aug 24 21:34:15 READYNAS ng-csd[13398]: E0824 21:34:15.760414 13398 GoogleDriveFS.cpp:185] Failed to fetch node! DATABASE_EXCEPTION: Extraction error: value already extracted Aug 24 21:34:15 READYNAS ng-csd[13398]: Failed to fetch node! DATABASE_EXCEPTION: Extraction error: value already extracted Aug 24 21:34:19 READYNAS ng-csd[13398]: Failed to get resource by parent id and name. parentId = 1RfZ5qgh1Jd0MRqnLVjMP2DKBpcl_YcsYqG8nGXoO2bY, name = file.jpg. Extraction error: value already extracted Aug 24 21:34:19 READYNAS ng-csd[13398]: Failed to fetch node! DATABASE_EXCEPTION: Extraction error: value already extracted Aug 24 21:34:19 READYNAS ng-csd[13398]: E0824 21:34:19.790344 13442 FSCache.cpp:254] Failed to get resource by parent id and name. parentId = 1RfZ5qgh1Jd0MRqnLVjMP2DKBpcl_YcsYqG8nGXoO2bY, name = file.jpg. Extraction error: value already extracted Aug 24 21:34:19 READYNAS ng-csd[13398]: E0824 21:34:19.790473 13442 GoogleDriveFS.cpp:185] Failed to fetch node! DATABASE_EXCEPTION: Extraction error: value already extracted Aug 24 21:34:19 READYNAS ng-csd[13398]: E0824 21:34:19.790591 13442 SyncUpsyncFile.cpp:359] Failed to update file. local file = /data/Drive_gdg/Google Photos/file.jpg, remote file = /Google Photos/file.jpg. INVALID_ARGUMENT: localPath or remotePath shall be file Aug 24 21:34:19 READYNAS ng-csd[13398]: Failed to update file. local file = /data/Drive_gdg/Google Photos/file.jpg, remote file = /Google Photos/file.jpg. INVALID_ARGUMENT: localPath or remotePath shall be file Aug 24 21:34:24 READYNAS ng-csd[13398]: Failed to get resource by parent id and name. parentId = 1RfZ5qgh1Jd0MRqnLVjMP2DKBpcl_YcsYqG8nGXoO2bY, name = paris.jpg. Extraction error: value already extracted Aug 24 21:34:24 READYNAS ng-csd[13398]: Failed to fetch node! DATABASE_EXCEPTION: Extraction error: value already extracted Aug 24 21:34:24 READYNAS ng-csd[13398]: E0824 21:34:24.035274 13398 FSCache.cpp:254] Failed to get resource by parent id and name. parentId = 1RfZ5qgh1Jd0MRqnLVjMP2DKBpcl_YcsYqG8nGXoO2bY, name = paris.jpg. Extraction error: value already extracted Aug 24 21:34:24 READYNAS ng-csd[13398]: E0824 21:34:24.035425 13398 GoogleDriveFS.cpp:185] Failed to fetch node! DATABASE_EXCEPTION: Extraction error: value already extracted Aug 24 21:36:41 READYNAS ng-csd[13398]: Failed to get node local name. Extraction error: value already extracted Aug 24 21:36:41 READYNAS ng-csd[13398]: E0824 21:36:41.254144 13398 FSCache.cpp:873] Failed to get node local name. Extraction error: value already extracted Aug 24 21:36:41 READYNAS ng-csd[13398]: E0824 21:36:41.256642 13398 FSCache.cpp:873] Failed to get node local name. Extraction error: value already extracted Aug 24 21:36:41 READYNAS ng-csd[13398]: E0824 21:36:41.258381 13398 FSCache.cpp:873] Failed to get node local name. Extraction error: value already extracted Aug 24 21:36:41 READYNAS ng-csd[13398]: E0824 21:36:41.259907 13398 FSCache.cpp:873] Failed to get node local name. Extraction error: value already extracted Aug 24 21:36:41 READYNAS ng-csd[13398]: E0824 21:36:41.264672 13398 FSCache.cpp:873] Failed to get node local name. Extraction error: value already extracted Aug 24 21:36:41 READYNAS ng-csd[13398]: E0824 21:36:41.266196 13398 FSCache.cpp:873] Failed to get node local name. Extraction error: value already extracted Aug 24 21:36:41 READYNAS ng-csd[13398]: E0824 21:36:41.267810 13398 FSCache.cpp:873] Failed to get node local name. Extraction error: value already extracted Aug 24 21:36:41 READYNAS ng-csd[13398]: E0824 21:36:41.269354 13398 FSCache.cpp:873] Failed to get node local name. Extraction error: value already extracted ... Aug 24 21:36:41 READYNAS ng-csd[13398]: E0824 21:36:41.280009 13398 FSCache.cpp:873] Failed to get node local name. Extraction error: value already extracted Aug 24 21:36:41 READYNAS ng-csd[13398]: E0824 21:36:41.281559 13398 FSCache.cpp:873] Failed to get node local name. Extraction error: value already extracted Aug 24 21:36:41 READYNAS ng-csd[13398]: E0824 21:36:41.283053 13398 FSCache.cpp:873] Failed to get node local name. Extraction error: value already extracted Aug 24 21:36:41 READYNAS ng-csd[13398]: Failed to get node local name. Extraction error: value already extracted Aug 24 21:36:41 READYNAS ng-csd[13398]: E0824 21:36:41.284624 13398 FSCache.cpp:873] Failed to get node local name. Extraction error: value already extracted Aug 24 21:36:41 READYNAS ng-csd[13398]: E0824 21:36:41.286243 13398 FSCache.cpp:873] Failed to get node local name. Extraction error: value already extracted Aug 24 21:36:41 READYNAS ng-csd[13398]: Failed to get node local name. Extraction error: value already extracted Aug 24 21:36:41 READYNAS ng-csd[13398]: Failed to get node local name. Extraction error: value already extracted Aug 24 21:36:41 READYNAS ng-csd[13398]: Failed to get node local name. Extraction error: value already extracted Aug 24 21:36:41 READYNAS ng-csd[13398]: Failed to get node local name. Extraction error: value already extracted Aug 24 21:36:41 READYNAS ng-csd[13398]: Failed to get node local name. Extraction error: value already extracted Aug 24 21:36:41 READYNAS ng-csd[13398]: Failed to get node local name. Extraction error: value already extracted Aug 24 21:36:41 READYNAS ng-csd[13398]: Failed to get node local name. Extraction error: value already extracted Aug 24 21:36:41 READYNAS ng-csd[13398]: Failed to get node local name. Extraction error: value already extracted Aug 24 22:33:12 READYNAS ng-csd[13398]: Encountered GoogleDriveError: 401 Aug 24 22:33:12 READYNAS ng-csd[13398]: E0824 22:33:12.522763 13398 GoogleDriveErrorMarshaller.cpp:92] Encountered GoogleDriveError: 401 Aug 24 22:33:13 READYNAS ng-csd[13398]: Request failed, now waiting 776 ms before attempting again. Aug 24 22:33:13 READYNAS ng-csd[13398]: W0824 22:33:13.627715 13398 WSClient.cpp:128] Request failed, now waiting 776 ms before attempting again. Aug 24 23:33:22 READYNAS ng-csd[13398]: Encountered GoogleDriveError: 401 Aug 24 23:33:22 READYNAS ng-csd[13398]: E0824 23:33:22.308737 13398 GoogleDriveErrorMarshaller.cpp:92] Encountered GoogleDriveError: 401 Aug 24 23:33:23 READYNAS ng-csd[13398]: Request failed, now waiting 662 ms before attempting again. Aug 24 23:33:23 READYNAS ng-csd[13398]: W0824 23:33:23.406625 13398 WSClient.cpp:128] Request failed, now waiting 662 ms before attempting again. Aug 25 00:33:31 READYNAS ng-csd[13398]: Encountered GoogleDriveError: 401 Aug 25 00:33:31 READYNAS ng-csd[13398]: E0825 00:33:31.477128 13398 GoogleDriveErrorMarshaller.cpp:92] Encountered GoogleDriveError: 401 Aug 25 00:33:32 READYNAS ng-csd[13398]: Request failed, now waiting 390 ms before attempting again. Aug 25 00:33:32 READYNAS ng-csd[13398]: W0825 00:33:32.772245 13398 WSClient.cpp:128] Request failed, now waiting 390 ms before attempting again. Aug 25 01:33:39 READYNAS ng-csd[13398]: Encountered GoogleDriveError: 401 Aug 25 01:33:39 READYNAS ng-csd[13398]: E0825 01:33:39.726773 13398 GoogleDriveErrorMarshaller.cpp:92] Encountered GoogleDriveError: 401 Aug 25 01:33:40 READYNAS ng-csd[13398]: Request failed, now waiting 668 ms before attempting again. Aug 25 01:33:40 READYNAS ng-csd[13398]: W0825 01:33:40.841905 13398 WSClient.cpp:128] Request failed, now waiting 668 ms before attempting again. Aug 25 02:33:48 READYNAS ng-csd[13398]: Encountered GoogleDriveError: 401 Aug 25 02:33:48 READYNAS ng-csd[13398]: E0825 02:33:48.316488 13398 GoogleDriveErrorMarshaller.cpp:92] Encountered GoogleDriveError: 401 Aug 25 02:33:49 READYNAS ng-csd[13398]: Request failed, now waiting 585 ms before attempting again. Aug 25 02:33:49 READYNAS ng-csd[13398]: W0825 02:33:49.414007 13398 WSClient.cpp:128] Request failed, now waiting 585 ms before attempting again. Aug 25 03:33:57 READYNAS ng-csd[13398]: Encountered GoogleDriveError: 401 Aug 25 03:33:57 READYNAS ng-csd[13398]: E0825 03:33:57.696195 13398 GoogleDriveErrorMarshaller.cpp:92] Encountered GoogleDriveError: 401 Aug 25 03:33:58 READYNAS ng-csd[13398]: Request failed, now waiting 273 ms before attempting again. Aug 25 03:33:58 READYNAS ng-csd[13398]: W0825 03:33:58.788640 13398 WSClient.cpp:128] Request failed, now waiting 273 ms before attempting again. Aug 25 04:34:28 READYNAS ng-csd[13398]: Encountered GoogleDriveError: 401 Aug 25 04:34:28 READYNAS ng-csd[13398]: E0825 04:34:28.741219 13398 GoogleDriveErrorMarshaller.cpp:92] Encountered GoogleDriveError: 401 Aug 25 04:34:29 READYNAS ng-csd[13398]: Request failed, now waiting 769 ms before attempting again. Aug 25 04:34:29 READYNAS ng-csd[13398]: W0825 04:34:29.858224 13398 WSClient.cpp:128] Request failed, now waiting 769 ms before attempting again. spinndown.log Aug 24 21:40:07 READYNAS noflushd[14387]: Enabling spindown for disk 1 [sda,0:0:TOSHIBA_DT01ACA100:94Q8JWAFS:MS2OA750:7200] Aug 24 21:40:07 READYNAS noflushd[14387]: Enabling spindown for disk 2 [sdb,0:1:TOSHIBA_DT01ACA100:94M7XYBNS:MS2OA750:7200] Aug 24 21:40:07 READYNAS noflushd[14387]: Enabling spindown for disk 3 [sdc,0:2:TOSHIBA_DT01ACA100:94M8AU0FS:MS2OA750:7200] Aug 24 21:40:07 READYNAS noflushd[14387]: Enabling spindown for disk 4 [sdd,0:3:TOSHIBA_DT01ACA100:3311NN6NS:MS2OA750:7200] Aug 25 03:58:34 READYNAS noflushd[14387]: Spinning down disk 2 (/dev/sdb). Aug 25 03:58:52 READYNAS noflushd[14387]: Spinning up disk 2 (/dev/sdb) after 0:00:16. Aug 25 04:09:33 READYNAS noflushd[14387]: Spinning down disk 3 (/dev/sdc). Aug 25 04:09:35 READYNAS noflushd[14387]: Spinning down disk 4 (/dev/sdd). Aug 25 04:09:43 READYNAS noflushd[14387]: Spinning up disk 3 (/dev/sdc) after 0:00:08. Aug 25 04:09:43 READYNAS noflushd[14387]: Spinning up disk 4 (/dev/sdd) after 0:00:05. Aug 25 04:14:03 READYNAS noflushd[14387]: Spinning down disk 1 (/dev/sda). Aug 25 04:14:06 READYNAS noflushd[14387]: Spinning down disk 2 (/dev/sdb). Aug 25 04:14:28 READYNAS noflushd[14387]: Spinning up disk 1 (/dev/sda) after 0:00:22. Aug 25 04:14:28 READYNAS noflushd[14387]: Spinning up disk 2 (/dev/sdb) after 0:00:20. Aug 25 04:14:49 READYNAS noflushd[14387]: Spinning down disk 3 (/dev/sdc). Aug 25 04:14:51 READYNAS noflushd[14387]: Spinning down disk 4 (/dev/sdd). Aug 25 04:14:58 READYNAS noflushd[14387]: Spinning up disk 3 (/dev/sdc) after 0:00:07. Aug 25 04:14:58 READYNAS noflushd[14387]: Spinning up disk 4 (/dev/sdd) after 0:00:05. Aug 25 04:19:29 READYNAS noflushd[14387]: Spinning down disk 1 (/dev/sda). Aug 25 04:19:32 READYNAS noflushd[14387]: Spinning down disk 2 (/dev/sdb). Aug 25 04:19:44 READYNAS noflushd[14387]: Spinning up disk 1 (/dev/sda) after 0:00:12. Aug 25 04:19:44 READYNAS noflushd[14387]: Spinning up disk 2 (/dev/sdb) after 0:00:10. Aug 25 04:20:04 READYNAS noflushd[14387]: Spinning down disk 3 (/dev/sdc). Aug 25 04:20:07 READYNAS noflushd[14387]: Spinning down disk 4 (/dev/sdd). Aug 25 04:20:19 READYNAS noflushd[14387]: Spinning up disk 3 (/dev/sdc) after 0:00:12. Aug 25 04:20:19 READYNAS noflushd[14387]: Spinning up disk 4 (/dev/sdd) after 0:00:10. Aug 25 04:25:20 READYNAS noflushd[14387]: Spinning down disk 3 (/dev/sdc). Aug 25 04:25:22 READYNAS noflushd[14387]: Spinning down disk 4 (/dev/sdd). Aug 25 04:25:30 READYNAS noflushd[14387]: Spinning down disk 1 (/dev/sda). Aug 25 04:25:32 READYNAS noflushd[14387]: Spinning down disk 2 (/dev/sdb). Aug 25 04:25:35 READYNAS noflushd[14387]: Spinning up disk 3 (/dev/sdc) after 0:00:13. Aug 25 04:25:35 READYNAS noflushd[14387]: Spinning up disk 4 (/dev/sdd) after 0:00:10. Aug 25 04:26:05 READYNAS noflushd[14387]: Spinning up disk 1 (/dev/sda) after 0:00:33. Aug 25 04:26:05 READYNAS noflushd[14387]: Spinning up disk 2 (/dev/sdb) after 0:00:30. Aug 25 04:30:35 READYNAS noflushd[14387]: Spinning down disk 3 (/dev/sdc). Aug 25 04:30:38 READYNAS noflushd[14387]: Spinning down disk 4 (/dev/sdd). Aug 25 04:30:50 READYNAS noflushd[14387]: Spinning up disk 3 (/dev/sdc) after 0:00:12. Aug 25 04:30:50 READYNAS noflushd[14387]: Spinning up disk 4 (/dev/sdd) after 0:00:10.Solved3.3KViews0likes16Comments
