stopped working. ethernet
1 TopicPowerline HDX Internet Just Stopped Working
Mac osx 10.12.6 Router Netgear N600 WNDR34500 I have a direct line from the router to my Mac, but I use my powerline for my home theater system in the other room via converted router to switch. I also have a single block XAV 101v2 which I picked up at a thrift shop that works, but I havent been using it. I've check pretty much everything I need to check to see if the rest of the system works and it does, but I only get the power and the ethernet lights to work on the blocks. Checked, cables, outlets from different room. The only thing I cant check is where I put in the original line to the wall from the router. Any suggestions? I went to work yesterday and everything worked fine, but when I came home the blocks werent working.976Views0likes1Comment
