systemd-journal
1 TopicReadyNAS 312 6.6.1 systemd-journal log
I see a lot of these style entires: * apache2[19277]: [warn] [client 192.168.1.118] mod_auth_token: SHM capacity FULL. Shift memory to fit one more token. ts_end 320f83f8" * in the systemd-journal log file. Is this a 'thing' to be concerned about? Yes, we are having some behavioural issues with this box (losing Readycloud app access via the VPN, the device showing "offline" in readycloud portal occasionally and the the NAS suddently being inaccessible locally which seems to crash Mac OS X FInder. Restarting Finder reconnects and it is OK again. We don't know if it is a local LAN problem. The device has 2 LAN sockets. Only one is connected, should we connect both or just try the other one for a while? Is there a log file that would indicate 'Network' connection errors? The standard web interface errors do not show any erros or warnings of this type at all. we have a case request out with Netgear support but I know that some of you are superb with these things. Thanks, Andy.3.5KViews0likes2Comments
