turn off
1 TopicRN10200 Unable to Boot or reset or reinstall OS
My ReadyNAS is invisible to raidAIR and doesn't even show up under my routers connected devices list. I've tried several times to factory reset and it doesn't seem to work. I tried upgrading firmware back sometime in the winter and since then the readyNAS got put away in a box. Recently went to use it again and remembered why it ended up in the box... I've tried an OS reinstall just now with 2 different USB sticks, both times the process goes about it's thing very quickly, but then nothing happens. Is the readyNAS toast or should I just keep trying with other USB drives? Also, the unit is unresponsive to the power button and passed the memory test. I'm kind of stumped.5.2KViews0likes14Comments
