ultra 4
2 TopicsReadyNAS Ultra 4 "Volume scan found errors that it could not easily correct."
Hi all! First time poster, long time lurker. After years of happy use of the Ultra 4, I have my first (major) issue. None of the shares are mounting, presumably due to the missing volumes. Further inspection indicates that the disk space is full "3940 GB (100%) of 3940 GB used". While I suspect this is a red herring, it's possible a runaway process filled it up. Following is a snippet of the most recent logs: Tue Feb 7 12:30:59 EST 2017 System is up. Tue Feb 7 12:29:59 EST 2017 The paths for the shares listed below could not be found. Typically, this occurs when the ReadyNAS is unable to access the data volume. share1 share2 share3 Tue Feb 7 12:28:40 EST 2017 Volume scan found errors that it could not easily correct. Please ensure that you have current backups of all valuable data before performing a full volume scan by rebooting the NAS through Frontview with the volume scan option enabled. Sun Feb 5 06:41:28 EST 2017 RAID scrubbing finished on volume C. Sun Feb 5 03:03:28 EST 2017 The on-line filesystem consistency check completed without errors for Volume C. Sun Feb 5 03:00:03 EST 2017 The on-line filesystem consistency check has started for Volume C. Sun Feb 5 00:00:24 EST 2017 RAID scrubbing started on volume C. Sun Jan 29 06:43:35 EST 2017 RAID scrubbing finished on volume C. Sun Jan 29 03:03:29 EST 2017 The on-line filesystem consistency check completed without errors for Volume C. Sun Jan 29 03:00:03 EST 2017 The on-line filesystem consistency check has started for Volume C. Sun Jan 29 00:00:18 EST 2017 RAID scrubbing started on volume C. Sun Jan 22 06:43:26 EST 2017 RAID scrubbing finished on volume C. Sun Jan 22 03:03:35 EST 2017 The on-line filesystem consistency check completed without errors for Volume C. I do not have a current backup, and only have around 40GB on the NAS that is worth saving. Any way to mount these up temporarily to see if I can delete a gigantic file or save the vitals before a rebuild? Is Skip Volume Check the way to go? I'm on Ubuntu for debugging, but can also use Windows tools. Thanks for any help!3.9KViews0likes6CommentsHome Network Permissions
Hi, this is my first time posting in any type of forum so please bare with me. I have searched this forum and the user manual for my Net Gear Ultra 4 server for answers and could not find exactly what i was looking for so it leaves me with generating a new thread. My computer knowledge and computer hardware knowledge is fairly good, but my knowledge when it comes to Networking sucks - which is proabably the reason I cant figure this out. I will start of by describing my "setup" The Netgear ultra 4 has 4 drives installed and is being used in a home setting. primary purpose is to store data in a central location which is backed up in a Raid and can be accessed by multiple devices on my home network. The server has 4 Share folders (Backup, Files, Music, Pictures, Videos). Most are self explanatory. I use the backup folder for my windows PC's. Im running Acronis True Image on each PC...Acronis saves incremental copies of my drives to this folder on my server. I have 2 windows PC's (both Win 7). One is mine and the other is being used by the kids I also have a suite of tablets, smartphones and smart TV's (mostly all running Android). And i have One Chrome Book thats used by the wife for surfing. I have a combination of hardwired and wireless devices. My PC and the TV's are wired. Everything else is wireless. The TV's are wired because i use them to access the server folders named Music, Pictures and Videos to stream the music, whatch videos etc. I think i have described my network in enough detail.....So now i will get to my question.... In the past when it was just my wife and I on my home network I was not concerned with the security/integrity of the files stored on the server. As a result I simply set all my share folders to Read/Write as the default access to all folders and subfolders. As i said this was fine until we now have more and more users accessing our wireless network....Kids friends, Wifes friends/parents etc. Im worried that one of them will simply open up windows explorer, navigate to network and start browsing my server or worse yet deleting data from the server. I guess one solution would be to set up a Guest password to my wifi router, but there are times that I would like for some of these users to have read access to my server. So how do i set up my server so that My PC has full read/write access to all files/folders on the server (perferably through the standard windows explorer Network 'folder') while any and all other devices that connect to my network will only have read access to the folders on my server via the same windows explorer Network folder? For instance I still want my tablets and TV's to be able to view and stream the content from the Music, Pictures and Video shares located on the server. Also If/when i upgrade my PC to a newer model how would i make that PC the so called "admin" pc for the server? thanks, Scott...
