unmanaged vs smart
1 TopicGS605AV replacement
My old GS605AV switch worked great as a simple Home Theater and network switch until yesterday. Now it will not power up. According to the GA605AV installation guide the GS605AV would “optimize audio/video streaming prioritization if it can recognize the pattern … otherwise you can use port based QoS to manually configure priority… .” Port 5 was highest priority and Port 1 the lowest. Considering getting a GS105 but what would be the best 5-port replacement for this situation?Solved436Views0likes5Comments
