upgrading openssh rsync slow
1 TopicUpgrading openssh help
Hi all, I've been suffering from really slow rsync speeds when copying files from one NV+ to another. Speeds around 700k/sec compared to having a computer in between doing the copying via afp/nfs/smb (10+m/sec). The issue it seems is described here - scroll down to Eirik comment. Openssh needs upgrading. https://community.netgear.com/t5/Using-your-ReadyNAS/Rsync-slow-as-heck-for-everyone-else/td-p/617599/page/6# I'm trying to find a good way to upgrade openssh... I installed the `apt` .bin but don't wan to `upgrade` as it will break everything.. I tried to `apt-get install openssh` but it couldn't find the package. I tried to follow his steps but fails to install build-essentials. # apt-get install build-essential zlib1g-dev libssl-dev Reading Package Lists... Done Building Dependency Tree... Done Some packages could not be installed. This may mean that you have requested an impossible situation or if you are using the unstable distribution that some required packages have not yet been created or been moved out of Incoming. The following information may help to resolve the situation: The following packages have unmet dependencies: build-essential: Depends: libc6-dev-sparc64 but it is not going to be installed E: Broken packages Can anyone please advise or help me on getting this sorted? What can I do to get openssh upgraded? These are 2 legacy ReadyNAS NV+ 4.1.14 , 1GB RAM. Thanks.Solved4.3KViews0likes12Comments
