usb activation
1 TopicSuggestion for additional "Getting Started" documentation
Mu mimo and beamforming where not enabled on initial installation on my units. With these features disabled the performance of the units was severly degraded for the optimum. I suggest that if you continued to send from the factory with these features disabled that the "Getting Started" documentation should not this and include simple instructions for activation. Also, could the usb ports be activated in the future for connecting hard drives?Solved
