vpn lte
1 TopicVPN Tunnel Connects but No Traffic Over LTE Connection
Hi, I'm trying to connect a windows pro 7 laptop running prosfae vpn client professional to an FVS338. The FVS338 is behind a DG834 router and I can successfully connect if I take the laptop home and use my ADSL connection there, however I would like to be able to connect using a 3G/4G LTE router, for mobile connections. It seems that the same working configuation connects over LTE but there is no traffic, I can't ping, or access anty devices behind the FVS338 (where I can from home). I am reasonably stumped now. I have tried switching between 3g and 4g connection, which is on the giffgaff / 02 network in the UK. The connection does provide internet access and the router has VPN pass through enabled. The remote client is getting a mode config assigned IP address via both methods. Below is the FVS338 router log which covers a successful connection over ADSL (dated May 4th) and the unsuccessful (although tunnel connected) connection from May 5th. Can anyone offer any advice on what I may try next? - Last output repeated twice - 2017 May 5 11:28:01 [FVS338] [IKE] Received unknown Vendor ID_ 2017 May 5 11:28:01 [FVS338] [IKE] Received Vendor ID: draft-ietf-ipsec-nat-t-ike-02__ 2017 May 5 11:28:01 [FVS338] [IKE] Received unknown Vendor ID_ 2017 May 5 11:28:01 [FVS338] [IKE] Beginning Aggressive mode._ 2017 May 5 11:28:01 [FVS338] [IKE] Received request for new phase 1 negotiation: 192.168.0.75[500]<=>82.132.233.187[627]_ 2017 May 5 11:28:01 [FVS338] [IKE] Remote configuration for identifier "fvs_remote.com" found_ 2017 May 5 11:28:01 [FVS338] [IKE] 192.168.30.1 IP address has been released by remote peer._ 2017 May 5 11:28:01 [FVS338] [IKE] ISAKMP-SA deleted for 192.168.0.75[4500]-82.132.233.187[19603] with spi:c619a4cdd2e57491:fd11cdf233cfb7ee_ 2017 May 5 11:28:00 [FVS338] [IKE] Purged ISAKMP-SA with proto_id=ISAKMP and spi=c619a4cdd2e57491:fd11cdf233cfb7ee._ 2017 May 5 11:27:48 [FVS338] [IKE] DPD R-U-THERE-ACK sent to "82.132.233.187[19603]"_ 2017 May 5 11:27:48 [FVS338] [IKE] DPD R-U-THERE received from "82.132.233.187[19603]"_ 2017 May 5 11:27:17 [FVS338] [IKE] DPD R-U-THERE-ACK sent to "82.132.233.187[19603]"_ 2017 May 5 11:27:17 [FVS338] [IKE] DPD R-U-THERE received from "82.132.233.187[19603]"_ 2017 May 5 11:26:49 [FVS338] [IKE] IPsec-SA established[UDP encap 4500->19603]: ESP/Tunnel 192.168.0.75->82.132.233.187 with spi=2575272257(0x997f8941)_ 2017 May 5 11:26:49 [FVS338] [IKE] IPsec-SA established[UDP encap 19603->4500]: ESP/Tunnel 82.132.233.187->192.168.0.75 with spi=36488848(0x22cc690)_ 2017 May 5 11:26:48 [FVS338] [IKE] Adjusting peer's encmode 61443(61443)->Tunnel(1)_ 2017 May 5 11:26:47 [FVS338] [IKE] No policy found, generating the policy : 192.168.30.1/32[0] 192.168.10.0/24[0] proto=any dir=in_ 2017 May 5 11:26:47 [FVS338] [IKE] Using IPsec SA configuration: 192.168.10.1/24<->192.168.30.0/24_ 2017 May 5 11:26:47 [FVS338] [IKE] Responding to new phase 2 negotiation: 192.168.0.75[0]<=>82.132.233.187[0]_ 2017 May 5 11:26:47 [FVS338] [IKE] Sending Informational Exchange: notify payload[INITIAL-CONTACT]_ 2017 May 5 11:26:47 [FVS338] [IKE] ISAKMP-SA established for 192.168.0.75[4500]-82.132.233.187[19603] with spi:c619a4cdd2e57491:fd11cdf233cfb7ee_ 2017 May 5 11:26:47 [FVS338] [IKE] 192.168.30.1 IP address is assigned to remote peer 82.132.233.187[19603]_ 2017 May 5 11:26:47 [FVS338] [IKE] NAT detected: Local is behind a NAT device. and alsoPeer is behind a NAT device_ 2017 May 5 11:26:47 [FVS338] [IKE] NAT-D payload does not match for 82.132.233.187[19603]_ 2017 May 5 11:26:47 [FVS338] [IKE] NAT-D payload does not match for 192.168.0.75[4500]_ 2017 May 5 11:26:47 [FVS338] [IKE] Floating ports for NAT-T with peer 82.132.233.187[19603]_ 2017 May 5 11:26:47 [FVS338] [IKE] Setting DPD Vendor ID_ 2017 May 5 11:26:46 [FVS338] [IKE] For 82.132.233.187[627], Selected NAT-T version: draft-ietf-ipsec-nat-t-ike-02_ 2017 May 5 11:26:46 [FVS338] [IKE] DPD is Enabled_ 2017 May 5 11:26:46 [FVS338] [IKE] Received Vendor ID: DPD_ - Last output repeated twice - 2017 May 5 11:26:46 [FVS338] [IKE] Received unknown Vendor ID_ 2017 May 5 11:26:46 [FVS338] [IKE] Received Vendor ID: draft-ietf-ipsec-nat-t-ike-02__ 2017 May 5 11:26:46 [FVS338] [IKE] Received unknown Vendor ID_ 2017 May 5 11:26:46 [FVS338] [IKE] Beginning Aggressive mode._ 2017 May 5 11:26:46 [FVS338] [IKE] Received request for new phase 1 negotiation: 192.168.0.75[500]<=>82.132.233.187[627]_ 2017 May 5 11:26:46 [FVS338] [IKE] Remote configuration for identifier "fvs_remote.com" found_ 2017 May 5 11:05:57 [FVS338] [IKE] Could not find configuration for 71.6.167.142[500]_ 2017 May 5 01:42:32 [FVS338] [IKE] Could not find configuration for 216.218.206.66[62517]_ 2017 May 5 00:48:15 [FVS338] [IKE] 192.168.30.1 IP address has been released by remote peer._ 2017 May 5 00:48:15 [FVS338] [IKE] ISAKMP-SA deleted for 192.168.0.75[4500]-82.132.244.237[49809] with spi:03a55f0cdcead227:febb7dc817284e05_ 2017 May 5 00:48:14 [FVS338] [IKE] Sending Informational Exchange: delete payload[]_ 2017 May 5 00:48:14 [FVS338] [IKE] ISAKMP-SA expired 192.168.0.75[4500]-82.132.244.237[49809] spi:03a55f0cdcead227:febb7dc817284e05_ 2017 May 4 18:57:37 [FVS338] [IKE] IPsec-SA expired: ESP/Tunnel 95.145.99.146->192.168.0.75 with spi=97374627(0x5cdd1a3)_ 2017 May 4 18:54:22 [FVS338] [IKE] IPsec-SA expired: ESP/Tunnel 95.145.99.146->192.168.0.75 with spi=43099881(0x291a6e9)_ 2017 May 4 18:41:52 [FVS338] [IKE] 192.168.30.2 IP address has been released by remote peer._ 2017 May 4 18:41:52 [FVS338] [IKE] ISAKMP-SA deleted for 192.168.0.75[4500]-95.145.99.146[4500] with spi:62bd7c46892d0fe9:e806e79130c7e000_ 2017 May 4 18:41:51 [FVS338] [IKE] Purged ISAKMP-SA with proto_id=ISAKMP and spi=62bd7c46892d0fe9:e806e79130c7e000._ 2017 May 4 18:41:51 [FVS338] [IKE] Purged IPsec-SA with proto_id=ESP and spi=1865101597(0x6f2b311d)._ 2017 May 4 18:41:51 [FVS338] [IKE] an undead schedule has been deleted: 'pk_recvupdate'._ 2017 May 4 18:41:51 [FVS338] [IKE] Deleting generated policy for 95.145.99.146[0]_ 2017 May 4 18:41:36 [FVS338] [IKE] IPsec-SA established[UDP encap 4500->4500]: ESP/Tunnel 192.168.0.75->95.145.99.146 with spi=1865101597(0x6f2b311d)_ 2017 May 4 18:41:36 [FVS338] [IKE] IPsec-SA established[UDP encap 4500->4500]: ESP/Tunnel 95.145.99.146->192.168.0.75 with spi=97374627(0x5cdd1a3)_ 2017 May 4 18:41:36 [FVS338] [IKE] Adjusting peer's encmode 61443(61443)->Tunnel(1)_ 2017 May 4 18:41:35 [FVS338] [IKE] No policy found, generating the policy : 192.168.30.2/32[0] 192.168.10.0/24[0] proto=any dir=in_ 2017 May 4 18:41:35 [FVS338] [IKE] Using IPsec SA configuration: 192.168.10.1/24<->192.168.30.0/24_ 2017 May 4 18:41:35 [FVS338] [IKE] Responding to new phase 2 negotiation: 192.168.0.75[0]<=>95.145.99.146[0]_ 2017 May 4 18:41:35 [FVS338] [IKE] Sending Informational Exchange: notify payload[INITIAL-CONTACT]_ 2017 May 4 18:41:35 [FVS338] [IKE] ISAKMP-SA established for 192.168.0.75[4500]-95.145.99.146[4500] with spi:62bd7c46892d0fe9:e806e79130c7e000_ 2017 May 4 18:41:35 [FVS338] [IKE] 192.168.30.2 IP address is assigned to remote peer 95.145.99.146[4500]_ 2017 May 4 18:41:35 [FVS338] [IKE] NAT detected: Local is behind a NAT device. and alsoPeer is behind a NAT device_ 2017 May 4 18:41:35 [FVS338] [IKE] NAT-D payload does not match for 95.145.99.146[4500]_ 2017 May 4 18:41:35 [FVS338] [IKE] NAT-D payload does not match for 192.168.0.75[4500]_ 2017 May 4 18:41:35 [FVS338] [IKE] Floating ports for NAT-T with peer 95.145.99.146[4500]_ 2017 May 4 18:41:35 [FVS338] [IKE] Setting DPD Vendor ID_ 2017 May 4 18:41:34 [FVS338] [IKE] For 95.145.99.146[500], Selected NAT-T version: draft-ietf-ipsec-nat-t-ike-02_ 2017 May 4 18:41:34 [FVS338] [IKE] DPD is Enabled_ 2017 May 4 18:41:34 [FVS338] [IKE] Received Vendor ID: DPD_ - Last output repeated twice - thanks in advance!8.6KViews0likes9Comments
