wifi region
1 TopicR8500 how to unlock wifi region
I've just unlocked a R8500 bought in US and now working in EU. You know that all the router wifi that are selled in US market have wifi region locked to United States or North America, but I've found a solution putting togheter ideas from community. You should connect not in wifi but wired to your router and for me have worked and if you try is at your risk if you are not sure stop youself. Step 1: You should enable Telnet on your R8500 and the solution is http://routerlogin.net/debug and you check as active the Telnet check box. Step 2: On you computer you have Telnet active, on Linux is by default on Windows 10 it's an add-on that you can activate from app / program installation Step 3: Assume you are now on Win10/8/7 you should activate command window with CMD Step 4: Activate at prompt the Telnet Step 5: The first Telnet command is "open" "IP address" of your R8500 and user and password as usual I've not tried routerlogin.net but I suppose that is working Step 6: at prompt command "burnsku" to check the actual configuration that should be "0x0001" Step 7: at prompt command "burnsku 0x0002" and you unlock the wifi region selection, you should give the "burnsku" to check the upadte a 0x0002 Step 8: Restart your R8500 and your Wifi region is now unlocked and you can choose your location.Solved8.5KViews2likes2Comments
