wifi router
2 TopicsNighthawk M1 battery charging problem
I have just bought a Netgear Nighthawk M1 through Telstra to enable working in the field. Plugged into the wallmount to charge and the battery seems to drain instead. It will only charge through USB which defeats the purpose of being completely mobile. There is a community discussion on this going back to 2014 but no obvious solution offered. Any suggestions?Getting the right router for fiber optic cable
We just moved into a new house in rural America. The ISP is a coop which ran fiber optic cable to our house. They said we don't need a modem due to being fiber optic and said we need to supply a router. Beyond that they don't really know much more. I would like to get a Nighthawk 1900 Wifi Router but don't know how to tell if it will be compatible, and the ISP doesn't either. Any advice or things specific things to look for would be appreciated.Solved100KViews0likes8Comments
