wifi setup r6300
1 TopicFrequent reset required on R6300 to restore wifi
Firmware: V1.0.2.78_1.0.58 I have to frequently reset R6300 to restore wifi. Only soft reset is required, just power off and on. Hardwired connectivity is nor affected. Sometimes it is required everyday, sometimes it is okay for a week or so. Worked fine for a long time (years) and the problem started a few months ago. I am using only 2.4Ghz. Any suggestions how to fix it?Solved3.7KViews0likes3Comments
