wifi speed
3 TopicsOrbi Query - Will an extra third “bridge” satellite help with daisy chain and overall wifi speed imp
In my current setup I have the Orbi router in the living room, then a satellite each in the bedrooms with closed doors. This is setup using daisy chain topology. I’m in India so we have a lot of interference within our walls and environment. The satellite signal in the “attached devices” page of the setup via the Orbi Desktop Login says "GOOD" for both satellites, but keeps dropping out at intervals. Wondering if I place an extra third satellite in the small bridge hallway between the living and the rooms, would the signals and speed improve for wifi overall across the home? Please reference attached floor plan layout of my home to understand how the router and satellites are setup. I’ve marked the third potential satellite placement as SAT 3 bang in the middle of the main router and the other two satellites. I’m running the latest firmware 2.1.1.16 for my device. Thank you.Speed listed on Netgear Genie much slower than speedtest.net
I am using a netgear C3700 N600 Wifi cable modem router. The router/mdodem is hardwired to my computer When I do a speedtest on Netgear Genie to www.netgear.com it says my download speed from this website is 631 Kbps. When I do a speedtest from www.speedtest.net is says my sownload speed is 88Mbps. Why the marked difference? What is my actual download speed?15KViews0likes8CommentsCant change wifi speed on Range Extender N300 from 145mbps to 300mbps?
The main wifi-router and the wifi-modem are both on the living room, next too each other and they are 10-15 meters from the wifi-extender. My room which contains a PS4, laptop and an iPhone 6, are 3-4 meters from the wifi extender. I've had my Netgear Wifi Router Extender N300 for a year now and it has never been this slow. It started two weeks ago when I was playing GTA Online on my PS4 and I had the worst connection ever. The whole game was lagging, on online and all other online games were also lagging on my PS4. I had this problem for 3 days so i decided to restart my extender. But that didn't fix the issue. All my online games on the PS4 were still lagging like and the internet was also slow on my iPhone 6 and my laptop. The coonection was ****! So i decided to reset the whole extender to factory settings and after I went through the installation process the internet was up and running but still a little bit slower than normally. I opened the wifi extender settings and saw that the wifi speed was set to 145mbps but it should be set on 300mbps... BUT I CANT CHANGE IT TO 300MBPS CAUSE THE BUTTON IS STUCK/UNCHANGEABLE??? IT WONT LET ME CHANGE IT TO 300MBPS???Solved11KViews0likes2Comments
