wireless unstable
1 TopicFirmware R6220-V1.1.0.66 problems with wireless connections
I upgraded from V1.1.0.64 to V1.1.0.66 and experienced the following problems: 1) google home device cannot connect to the wifi (5G connection) 2) smart plugs accessed thru Smart Life app on my phone go offline and come back on line about twice a minute. (2.4G) 3) Cell phones configured for both 2.4 and 5 G switch between connections every couple of minutes. Reloaded saved configuration from 2 weeks ago, no improvement. Installed firmware V1.1.0.64 and everything was stable again. ( Installed firmware V1.1.0.66 and problem re-appeared. Firmware installs done as admin thru web browser with ethernet connection to port 1 on 6220. This R6220 is being used as a wireless access point. Currently working and stable using firmware V1.1.0.64.Solved
