Reply
WAX610 extenders not connecting
redders123
Tutor
Hi there - 3 x WAX610s have worked faultlessly since Nov 20, but in the past few days, despite no changes to the network, we've seen these devices disconnecting at random times. My plan was to factory reset all the units. I started with the extenders (leaving the root device FirstFlrLanding alone), I performed a factory reset on both extenders, but now they won't/don't connect to the selected network (see image) I've checked, and all devices are on the latest firmware. Any suggestions?  Each unit is powered with a mains adapter (not PoE).
Message 1 of 8
RaghuHR
NETGEAR Expert
Re: WAX610 extenders not connecting
Hi @redders123
Do you know any network topology changed recently or anything causing this issue?  Are these devices are managed by Insight?
Could you please send me the detailed logs downloaded from the monitoring page after you do the factory reset? Upload into google drive or something similar. Send me link via PM to download.
Message 2 of 8
redders123
Tutor
Any suggestions please?
The root device is working as expected, but having reset 2 extenders (due to repeated disconnection issues), I can 'claim' the reset devives, but they then fail to connect - this is what the cloud logs on one of these devices reports:
curl_easy_perform(url='https://registration.ngxcld.com/registration/register') failed with error code 60: 'Error'.
2020-03-03 01:01:34 (18521):logic.c:405 ERROR: Can't' make register request.
2020-03-03 01:01:34 (18521):xagent.c:289 WARNING: Failed to register device.
2020-03-03 01:01:34 (18521):xagent.c:297 WARNING: Sleeping for 10 secs.
2021-08-07 10:33:13 (18521):xagent.c:309 INFO: Device is registered successfully: id='3EGZHT68-3110-335-190034104', hardwareId='6AC40A230019A', claimCode='GPQZ5AB8GEWB2M3F0'.
Message 3 of 8
redders123
Tutor
@Raghu @davys Thanks for your help - the bizarre solution (as suggested by @davys) was to change the secondary DNS settings on the root device from the gateway (192.168.1.1) to 8.8.8.8. Once I'd done this I perfomed another reset on the WAX610 extenders then claimed them through the insight cloud interface - both extenders then connected and appear to be working fine.
Message 4 of 8
schumaku
Guru
The gateway DNS does refer to the ISP supplied DNS IPs typically, comes in along with the public IP by DHCP. Some trends with the ISP seem to provide safe DNS only - what could be nice as long as using a Web browser, but painful on IoT as it does just happen in the dark....
Message 5 of 8
RaghuHR
NETGEAR Expert
Hi @redders123
Could you please let us know if you can try our beta firmware which is having the potential fix?
Thanks,
Raghu
Message 6 of 8
redders123
Tutor
Hi there, sure, I’m happy to try it but my insight subscription expires tomorrow. Will that be an issue?
Best
Message 7 of 8
redders123
Tutor
Hi Raghu,
I've extended my Insight subscription for another year - please send me a link to the beta firmware.
Best
@RaghuHR wrote:
Hi @redders123
Thanks,
Raghu
Message 8 of 8
Top Contributors
Discussion stats
  • 7 replies
  • 2100 views
  • 1 kudo
  • 3 in conversation
Announcements
