Reply
we could not verify the certificate: reason = untrusted
Cofran268
Tutor
Hello,
Since 2 months, I'm not able to acces to my WAX.
On windows, Edge and Firefox return that message: "we could not verify the certificate: reason = untrusted" without the possibility to pass thrue.
I never change or set certificate.
Do you have an idee?
Message 1 of 12
Accepted Solutions
Cofran268
Tutor
Re: we could not verify the certificate: reason = untrusted
I finally found. It comes from Windows wireless setting. I switched from public to private setting and it's now ok!
Sorry for the picture in french
Message 10 of 12
All Replies
SaHi
Hi,
I have the same issue.
Additionally:
It happens on one device (PC) and on all browsers (Firefox, Edge, Chrome). On my laptop I still can access the router. As said by @Cofran268 it's a simple text message without the possibility to pass through. Tried IP of the router as well as routerlogin.net or orbilogin.com. Router is working fine, just cannot access the router settings on my pc.
Message 2 of 12
schumaku
Guru
It's a self-signed certificate, (generated and?) loaded during the initial device installation.
In general, any browser does allow to accept (I don't say trust or the like) a self-signed certificate. The only exception might be with Enterprise-managed or -operated systems explicitly allowing correct PKI-signed certificates or similar.
As of writing, Netgear does not offer the ability to update or replace the certificate and private key on the WAX6xx nor on the WAC5xx.
Message 3 of 12
schumaku
Guru
This tells me that that one device has some enterprise or business policies in place very likely.
Netgear used to distribute private keys and PKI signed (Entrust) certificates with each device. Needless to say, this was a major security risk, because all or series from similar models came with the exact same private key (and cert).
Message 4 of 12
DavidGo
NETGEAR Expert
Hi @Cofran268
We are aware of a similar issue when accessing the Orbi Pro admin page (SXR80 and SXR30) but I have not seen other reports of this issue happening on WAX600 series AP's.
To help debug further could you please provide the following:
1. Could you try to access the AP admin page using a different laptop, PC or mobile device and check if the issue is also observed there?
2. Is the AP managed only using the local admin page, or in Insight?
3. Do you see this issue on a single AP or multiple AP's?
4. Do you recall when the issue first appeared, if it coincided with any other event? i.e. AP firmware update, web browser update, Windows OS update?
Thanks
DavidGo
Message 5 of 12
Cofran268
Tutor
I tried on 2 differents Win11, same result. But it works with IOS
The AP is manage using local admin page
On multiple AP's
No, I cannot rememenber.
More information:
My Wax610 has the latest firmware
I tried to disable all functions of Bitdefender
Message 6 of 12
schumaku
Guru
Typical message from some intermediate security systems (programs, appliances, ...) - not something originating from the access point, which is almost certainly making use of the default self-signed certificate - which -of-course- can't be validated. In this example a SonicWall:
These are not problems with the managed system, no matter it's a security appliance, a router, a wireless access point. Figure out what wonderful security software does intercept the connection here -and- insert a text message into the https stream.
Strongly doubt this is something similar to the change in some of the browsers looking for certain certificate usage @DavidGo
Message 7 of 12
schumaku
Guru
Said that: In case it's an issue with the https connection, certificate, ... these would be shown in the Web browser context, not as part of the Web page content (as shown before).
Message 8 of 12
DavidGo
NETGEAR Expert
Hi @Cofran268
I agree with @schumaku here, it looks more like something is intercepting the traffic on Windows 11 devices and preventing from accessing the AP local admin page. The fact it also still works on iOS device points towards an issue specific on the Windows 11 machines.
I have tested here with Windows 11 (and Windows 10) and I am unable to reproduce the issue. Other than the security warning message which is expected, I can progress past it each time. Other than Bitdefender, is there any other security software (on the Win 11 devices) that could be blocking the access?... is Bitdefender totally disabled when testing?
@schumaku yes I agree it is different than what we are seeing on Orbi Pro. It just rung a bell initially but agreed it is different here.
Thanks
David
Message 9 of 12
Cofran268
Tutor
Message 10 of 12
schumaku
Guru
Negative. Neither Windows nor Microsoft Defender and Windows Firewall do show a message inside of the the Web browser pop-in such in-line text messages. Could be that changing from Public to Private does change the firewall profile - whatever security software does come into play there - and activates some 3rd party security ***** using the official method intended by Microsoft..
Message 11 of 12
SaHi
Hi all,
Tried several things (including what @Cofran268 said). Also tried several Bitdefender settings. Finally I deleted everything from Bitdefender and rebooted. Tried again and problem solved. I re-installed Bitdefender clean. Tried again and received the message that it is a untrusted connection, but now I could choose to trust it anyway and proceed. I've put it on the whitelist (as was before) and now I proceed to login immediatly.
Problem solved.
Thanks for the help!
Message 12 of 12
Top Contributors
Discussion stats
  • 11 replies
  • 1450 views
  • 1 kudo
  • 4 in conversation
Announcements
