- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Assistance interpreting logs from cm700 Modem regarding slow internet.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello, I'm having an issue with my internet being intermittently slow, and cutting out. I have worked with my ISP, and they ensure that I have a solid connection to my site, and I have made sure that my wiring is all fresh, and settings are correct. I am still seeing connection speeds that dip down extremely low back and forth throughout the day. I already ruled out my router because I hard wired straight to my modem, bypassing the router completely, and the slowness persists. I have the following logs from my modem, I'm hoping maybe someone can assist in giving me an idea of what they mean. Thank you in advance:
Downstream Bonded Channels | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Upstream Bonded Channels | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
and then these from the Event Logs:
Time | Priority | Description |
Sep 30 2022 05:49:35 | Warning (5) | Lost MDD Timeout |
Sep 30 2022 05:49:52 | Error (4) | Map Request Retry Timeout |
Sep 30 2022 05:50:03 | Warning (5) | Lost MDD Timeout |
Sep 30 2022 06:21:14 | Error (4) | Service Change Response rejected - Invalid transaction ID |
Sep 30 2022 06:21:15 | Warning (5) | Lost MDD Timeout |
Sep 30 2022 07:11:24 | Error (4) | Service Change Response rejected - Invalid transaction ID |
Sep 30 2022 07:11:34 | Warning (5) | Lost MDD Timeout |
Sep 30 2022 07:20:59 | Error (4) | Service Add Ack rejected - Invalid transaction ID |
Sep 30 2022 07:21:34 | Warning (5) | Lost MDD Timeout |
Sep 30 2022 07:26:55 | Error (4) | Service Change Response rejected - Invalid transaction ID |
Sep 30 2022 07:27:41 | Warning (5) | Lost MDD Timeout |
Sep 30 2022 07:30:48 | Error (4) | Service Change Response rejected - Invalid transaction ID |
Sep 30 2022 07:30:51 | Warning (5) | Lost MDD Timeout |
Sep 30 2022 07:33:35 | Error (4) | Service Change Response rejected - Invalid transaction ID |
Sep 30 2022 07:33:55 | Warning (5) | Lost MDD Timeout |
Sep 30 2022 07:35:17 | Error (4) | Service Change Response rejected - Invalid transaction ID |
Sep 30 2022 07:35:18 | Warning (5) | Lost MDD Timeout |
Sep 30 2022 07:37:46 | Error (4) | Service Change Response rejected - Invalid transaction ID |
Sep 30 2022 07:38:09 | Warning (5) | Lost MDD Timeout |
Sep 30 2022 08:02:44 | Error (4) | Service Change Response rejected - Invalid transaction ID |
Sep 30 2022 08:02:45 | Warning (5) | Lost MDD Timeout |
Sep 30 2022 08:19:55 | Error (4) | Service Change Response rejected - Invalid transaction ID |
Sep 30 2022 08:20:04 | Warning (5) | Lost MDD Timeout |
Time Not Established | Critical (3) | DHCP failed - RS sent, no RA received |
Time Not Established | Error (4) | Primary lease failed, IPv4 fallback initiated |
Sep 30 2022 08:38:16 | Warning (5) | MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1 |
Sep 30 2022 08:38:18 | Warning (5) | RCS Partial Service |
Sep 30 2022 08:38:36 | Warning (5) | Lost MDD Timeout |
Sep 30 2022 08:46:49 | Error (4) | Map Request Retry Timeout |
Sep 30 2022 08:46:51 | Warning (5) | Lost MDD Timeout |
Sep 30 2022 08:54:29 | Error (4) | Service Change Response rejected - Invalid transaction ID |
Sep 30 2022 08:54:56 | Warning (5) | Lost MDD Timeout |
Sep 30 2022 08:59:27 | Error (4) | Service Change Response rejected - Invalid transaction ID |
Sep 30 2022 08:59:35 | Warning (5) | Lost MDD Timeout |
Sep 30 2022 09:02:59 | Error (4) | Service Change Response rejected - Invalid transaction ID |
Sep 30 2022 09:03:02 | Warning (5) | Lost MDD Timeout |
Sep 30 2022 09:20:33 | Error (4) | Service Change Response rejected - Invalid transaction ID |
Sep 30 2022 09:20:35 | Warning (5) | Lost MDD Timeout |
Sep 30 2022 09:26:20 | Error (4) | Service Change Response rejected - Invalid transaction ID |
Sep 30 2022 09:26:35 | Warning (5) | Lost MDD Timeout |
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Assistance interpreting logs from cm700 Modem regarding slow internet.
You have errors and criticals that the ISP needs to review and help resolve.
https://highspeed.tips/docsis-events/
Power levels are too high:
https://kb.netgear.com/24311/Power-level-guidelines-for-a-NETGEAR-cable-modem-router?article=24311
Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.
Be sure there are no coax cable line splitters in the between the modem and ISP service box. Be sure fittings are snug.
Be sure your using good quality RG6 coax cable up to the modem.
Be sure to power OFF the modem for 1 minute then back ON.
https://community.netgear.com/t5/Cable-Modems-Routers/General-info-and-Troubleshooting-for-Cable-Mod...
https://www.duckware.com/tech/solving-intermittent-cable-modem-issues.html
