- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Best way to extend C6250 cable modem/router range?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I currently have a netgear C6250 cable modem router combo. It has worked well for the longest time and I have a detached garage that I was trying to extend the signal to for a security camera and television. I purchased an AC750 wifi range extender to try and do this quick and easy. The problem is that the wifi extender seems to mess up the entire network. My Wifi becomes very slow and will disconnect randomly when the device is plugged in. Not sure why this is causing such a problem but it's not a solution that works. What would be the best way to extend my wifi with this cable modem router combo? I've had it for a couple years so didn't know if it may just be time to upgrade my system or if there is a more cost-effective solution.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Best way to extend C6250 cable modem/router range?
What AC750 did you buy? AC750 is a speed and not a model.
Did you setup the ac750 with the same ssid as the c6250 or a separate one?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Sorry my apologies! It's the model EX3110 (AC750 wifi range extender)
https://www.netgear.com/support/product/ex3110.aspx.
I'll have to plug back in and check it to verify, but I believe it was on the same SSID.
- Mark as New
- Bookmark
- Subscribe
- Permalink
the EX3100 isn't a mesh extender. So make sure to have it using a different ssid from the primary router.
Also, it isn't the fastest extender and is pretty basic. so only have devices connecting to it if they're in that zone that didn't have coverage or had poor service.
Overall, extenders are great at adding extra coverage and coving dead spots but if an area already has wifi coverage (so long as its half decent) they won't really boost speeds because of how they work.
- Mark as New
- Bookmark
- Subscribe
- Permalink
also, make sure you're using the 5ghz.
2.4ghz is a slow network and sensitive to interference.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks! Yes I was using the 5 Ghz band. I'll check the SSID's. If I'm still not happy I'm guessing I'll invest in a mesh extender
