- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
C3700 N600 WiFi Intermittent Internet Connection Issues - Spectrum Internet Provider
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello,
I've been having internet connection issues for about 3 weeks. The internet is working fine, then I lose connection. Typically, I turn the modem off and then back on, and everything is fine. Sometimes I lose it once a day, other days, I lose connection multiple times. I spoke with Spectrum (ISP) and they blamed it on the modem. I'm struggling to believe it, but do not have a good way to validate, either way.
1) I only have wireless connections. Not sure I have a LAN cable to connect to anything
2) Not successfull (most likely user error) in connecting to the modem to obtain event logs and connection information.
Any suggestions would be appreciated.
Thank you!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: C3700 N600 WiFi Intermittent Internet Connection Issues - Spectrum Internet Provider
What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Please post a copy and paste of the modems connection status page.
Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Be sure to power OFF the modem for 1 minute then back ON.
https://community.netgear.com/t5/Cable-Modems-Routers/General-info-and-Troubleshooting-for-Cable-Mod...
https://www.duckware.com/tech/solving-intermittent-cable-modem-issues.html
- Mark as New
- Bookmark
- Subscribe
- Permalink
Advanced Screen screenshot
- Thank you
- Mark as New
- Bookmark
- Subscribe
- Permalink
Ya, thats not the information we are looking for.
Also please do not post MAC address or serial number information in public forums.
- Mark as New
- Bookmark
- Subscribe
- Permalink
OK, I'm sorry. I'm completely ignorant on this stuff. Please see attached and let me know if that is the connection status page you are looking for.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thats it. Thank you.
https://kb.netgear.com/24311/Power-level-guidelines-for-a-NETGEAR-cable-modem-router
Looks ok, maybe a tad bit high, however seems ok for now.
Check on the channels suggestion.
Also scan around your home for wifi neighbors...how many do you see?
- Mark as New
- Bookmark
- Subscribe
- Permalink
OK, I've set the channels of both the 2.4 and 5 G per your above suggestion, to see if I have more consistant performance. Fingers crossed.
Also, as I look now, there are eight (8) additional connections listed (neighbors, I'm guessing?). None are more than one bar
Finally, had a different one today: my 2.4G kicked out while my 5G remainded perfectly fine (Two laptops side by side...one can't use anything but the 2.4g). I didn't realize the logs would clear after I made the above channel changes, so I lost the event logs leading up to that problem. When I tried to connect to the 2.4G, my system asked for the network password, and said it had been changed? I powered down and restarted the router, and everything works just fine, again.
Thanks, again, for the help!
- Mark as New
- Bookmark
- Subscribe
- Permalink
https://kb.netgear.com/24231/How-do-I-back-up-the-router-configuration-settings-on-my-Nighthawk-rout...
- Mark as New
- Bookmark
- Subscribe
- Permalink
No change in dropped connections. In fact, new settings may have been worse. I returned the settings back to their original "Auto". Any other suggestions? Any reason to believe the modem is giving me issues? It is fairly new (1 1/2 - 2 years old), so I'm hesitant to think it needs replacement, and figure I might have the same issue with a brand new unit.
Any thoughts or direction would be appreciated.
Thank you
