- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
C6250 will not connect
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: C6250 will not connect
So, you need help with an C6250 modem/router?
What does "won't work" mean? It cannot connect to the Internet? Something else?
Take us through what you are doing and where it goes wrong.
You can help people to help you by providing the information suggested in this forum's header:
Subject (Include model number and brief summary)
Model (Recommended - Helps the community give the best answers)
Body (Include additional detail including model version, firmware, OS and environment where relevant.)
They are there for a good reason.
Manuals are also a good place to start.
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
Begin with the Quick Start/Installation Guide.
You may have done that already. I can't tell from your message.
I mention it because Netgear gave up on supplying paper manuals and CD versions some years ago and people sometimes miss the downloads.
- Mark as New
- Bookmark
- Subscribe
- Permalink
1. what are all the led's on it doing?
2. have you tried hardwiring a pc/laptop into it?
3. if you can hardwire a pc/laptop into it, are you able to access it though the browser (not the app)
4. Is your isp still able to see/ping the modem from their end?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Are you able to access it by connecting to the wifi and using a browser (not the app)
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
You can't connect to the wifi at all?
then you might need to borrow a laptop or buy a usb/ethernet adapter to hardwire into it to access it
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Wynter26 wrote:
Unfortunately, where I live the signal without Wi-Fi is very spotty so I’m kind of in a standstill.
What signal is that? Mobile phone?
What has that got to do with connecting to the C6250?
You said earlier:
.... the Nighthawk app cannot connect to it at all.
I'd still. like to know what you are doing and where things go wrong.
Is this the Nighthawk app on a mobile device? Is "it" the modem router?
Even "cannot connect" is thin on detail. What tells you that? You get a message from the Nighthawk app? Which one? Android? iOS?
Here's another unknown?
When I try to use the app with Wi-Fi on I’m unable to sign in for some reason (password is not the password).
"password is not the password"?
There are several passwords in these things.
The password for the wifi is the one written on the bottom of the modem/router. The SSID is also there,
Before you can do anything, you need to connect to the wifi with those details. Dig out that manual (see above) and read the section Join the WiFi Network of the Modem Router
Or just follow the bit in the Quick Start guide:
"To connect using a WiFi connection, use the WiFi network name (SSID) and password on the product label."
Once you have done that, you do not have to use the Nighthawk app. You can use the browser on your mobile device or anything else connected to the wifi, like a PC.
Here too, the Quick Start guide helps:
View or Change the Modem Router Settings
As always, the devil is in the detail, and the solution is in clear descriptions of what is happening.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Wynter26 wrote:
When I say I can’t connect to the Wi-Fi I mean I am able to see that the Wi-Fi is there.
That's good.
Can you connect to it with the default wifi password in the product label on the bottom of the thing?
To make life complicated, they don't call it a password. It's also ln known as a passphrase.
If your phone supports it, try using "WPS". That's a push button thingy that doesn't need any keyboard input. You just press the buttons on the C6250 and whatever mobile device you have.
