Orbi WiFi 7 RBE973
Reply
C6300BD and QoS
GinAZ
Follower
C6300BD and QoS
Having issues with high latency (my internet service is 100Mbps) on a device that is used for online gaming, while another device streams shows/movies. I want both devices to be able to do their thing at the same time, but remove the high latency from the gaming machine. So I had thought to simply put the online gaming device/game application as highest priority in QoS.
However I'm not finding a QoS setup option in the genie. Does this unit not have the option to do this? Any suggestions?
Message 1 of 2
DarrenM
Sr. NETGEAR Moderator
Re: C6300BD and QoS
Hello GinAz
This unit does not have Qos but with a 100Mbps you shouldn't be having to many problems gaming. I would check your cable connection on your modem make sure its tight might want to change the ethernet cord it could be bad and if your using wifi maybe you want to change your wireless channel. If your still see a bunch of problems I would contact your isp tech support have them look at the diagnostics on the router to see if packet loss is happening.
DarrenM
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 4620 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
