- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
C6300v2 needs firmware upgrade
- Mark as New
- Bookmark
- Subscribe
- Permalink
Have had the same exact problem 2 years ago there hasn't been any fix to this issue to nighthawk it's worthless the app.
You have to manually check the router gateway if any icon pops up for firmware updates against the provider you use.
Haven't seen any in 2 years
Calling support thru netgear and provider has proved nothing went thru whole deal Uninstall reinstall the factory reset and still the same issue.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: C6300v2 needs firmware upgrade
C and CM series modems are not user FW updatable. Only the ISPs can push FW updates to these modems after NG sends them FW for the ISP to first test out on there systems to be sure it works, then they can push out to these modems. Be aware that some ISPs will not update user owned modems. Been like this for a long time.
If your having problems, please post the details and we can review and see if we can help out.
