Orbi WiFi 7 RBE973
Reply
C7000
DuckFan
Follower
C7000
How can I access my router if I cannot find the admin password?
Message 1 of 2
Guru
Re: C7000
Wire connect a PC to the router and factory reset the router using the back push pin button. Hold it in for 10 seconds then let go. Then log in to routerlogin.com or 192.168.1.1 using a wired PC and web browser and walk thru the setup wizard. Be sure write down all important information for safe keeping later on.
https://kb.netgear.com/9665/How-do-I-perform-a-factory-reset-on-my-NETGEAR-router
https://kb.netgear.com/22697/How-do-I-install-my-NETGEAR-router-using-the-router-web-interface
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 153 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
