Orbi WiFi 7 RBE973
Reply
CAX30S Radio Buttons turned off
argp718
Tutor
My nephew went to fiber optics and gave me his CAX30S Netgear Nighthawk cable modem/router. I activated it with my cable provider. I am able to get on the internet using my desktop (Windows 10) and the ethernet cable (Cat 5e).  I cannot log on to this device to change any settings or to find out the firmware version (it just times out). I cannot access any WiFi connections. I assume that is because the radio buttons are not on.  When I press the on/off radio button on the unit, nothing happens.  When I do a power cycle or request the cable company to do a reset, the radio buttons do light up briefly and then turn off.  This device does not show up in a WiFi list or a Bluetooth list. Any suggestions would be appreciated. Thank you.
Message 1 of 5
Accepted Solutions
Guru
Re: CAX30S Radio Buttons turned off
Did you factory reset it before setting it up?
If not, start there. Push and hold reset for 7-15 seconds while powered on.
Message 2 of 5
All Replies
Guru
Message 2 of 5
argp718
Tutor
Thank you for that suggestion.  I did hit the reset on the unit yesterday on two different occasions but I only held it for maybe 2 or 3 seconds.  I will try again.
Message 3 of 5
argp718
Tutor
It worked.  Thanks so much.
Message 4 of 5
Guru
Glad it worked! You might mark it solved so others aren't still trying to fix it.
A backup is a good idea as well in case you have to reset it in the future.
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 994 views
  • 3 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
