- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
- « Previous
- 1
- 2
- Next »
CAX80-100NAS with Xfinity wifi texting failing
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: CAX80-100NAS with Xfinity wifi texting failing
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks for the suggestion.
That is a lot of effort you put in!
I would like to find the cause of the issue. If I go through what you did and have to reset every device in my house to the new wifi (no small task), if the cause of the original issue isn't found, it may just happen again.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Note that I did erase mine and reconfigure it early last week, but I reused the SSID name and didn't uninstall and reinstall the nighthawk app.
The issue persisted.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Interesting find. 🤔
Wondering why a factory reset and use of a different SSID name and password or maybe just a different SSID name would effect this. Or if removing the NH app and re-installing though I think I saw in a different forum someone had mentioned they removed the NH app, then re-installed it and then messages started to work. No sure how the NH app would play a roll in all this. Ya, seems like there is something happening that needs to be figured out.
@DayneJake1 when you FR your unit, did you setup from sratch using the NH app or PC and web browser?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I did everything by Web GUI.
Only time I touched NH app was to look at turning off the Armor 2 days after the reset and reconfigure.
Mine did work for about 12 hours after reset then slowly started the issue again. My wife's never worked even after the reset. She came home after mine worked for about 7 hours. (with the issue reappearing for me a few hours later.)
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
So far going on 20 hours and photo texts (MMS) are still going out and be receiving by text while connected to my home's WIFI. I've only seen one other weird issue and that is with my Samsung email app, when I try emailing a picture from my cellphone while connected to my home's WIFI say to another email address and I've tried this with a few different ones that photos send out but when they are received it shows the file is corrupt or the picture is won't load and look right. But when I send out photos by email via cellular data pictures go out and are received perfectly fine. So issues still exist and it is definitely a Samsung/Xfinity Mobile/Android/ and Netgear issue...
I"m just happy the MMS/photo text issue seems fixed.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Last night before going to sleep, I tested the Picture/MMS texting and it was working over WIFI.... this morning after no changes the Picture/MMS texting over WIFI is NO LONGER working AGAIN!
Something in the cellular network/Android/Samsung must be corrupting or messing with the Router functions.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Probably my final report because I'm about ready to jump ship and buy a new modem and router... and go with a different brand altogether. My MMS/picture texting is back working again, I did nothing for it to start working again... but my Samsung emails will send out emails without photo attachments, but now the minute I add a photo attachment it is unable to send.
Good luck everyone.
- Mark as New
- Bookmark
- Subscribe
- Permalink
What 2 settings are you referring to... because I've spent easily 20+ hours this past week and I've played with every setting in every menu on the Samsung phone, Netgear Router, and within Google Messages.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I did one last troubleshooting... for the email issue not allowing pictures to be sent over the WIFI, this block ONLY occurs on the 5GHZ SSID, not the 2.4GHZ SSID. Pictures go out perfectly and are received perfectly via email on the 2.4GHZ. So the fix for now is to only use the 2.4GHZ SSID, until I can purchase new equipment.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Checking with the both of you to see if the following on the CAX80 has been checked?
Disable IPSec ALG from GUI (ADVANCED->WAN Setup-> Click "Disable IPSec ALG" checkbox) and give it a try.
Thank you.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have made this change and will test for a few days. So far it looks good after 2 hours.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- « Previous
- 1
- 2
- Next »
