Orbi WiFi 7 RBE973
Reply
CAX80 Only Power LED on
Kokoro
Hi. I came home one day to find my router not working. Only the power LED was lit up. I have tried unplugging it, resetting it, holding down reset, with both power on and disconnected. The two buttons on the bottom do nothing. I can't find anything on the Internet either.
Please help!
PS, when plugging in router all LEDs turn on for a second. Lights 1 2 3 4 stay lift for about five seconds.
Message 1 of 4
Guru
Re: CAX80 Only Power LED on
Pull the power adapter from the wall out let. Disconnect the ISP coax cable from the modem. Disconnect all other LAN cables from the modem. Power ON the modem. Does the Up or down link LEDs turn on or blink any?
Might try a different power adapter that has same volts and amps...
Message 2 of 4
Kokoro
No change.
Message 3 of 4
Guru
I would return the unit if you recently bought it and find another or make contact with NG support and ask about RMA options:
https://my.netgear.com/support/contact.aspx
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 2256 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
