Orbi WiFi 7 RBE973
CAX80: Poor Cable Connection Status
brownbear55
Guide
Hi everyone. I have Xfinity's Gig speed Internet plan and recently purchased the Nighthawk CAX80. Currently, its cable connection status shows as poor.
I did a quick search in the forums and I come across multiple responses that state to have the ISP come out to check the line up to the modem. Before I do that, I was wondering if anyone had any interpretation on the diagnostic results below:
Startup Procedure
Procedure Status Comment
Acquire Downstream Channel405 MHzLocked
Connectivity StateOKOperational
Boot StateOKOperational
SecurityEnabledBPI+
Downstream Bonded Channels
Channel Lock Status Modulation Channel ID Frequency Power SNR Correctables Uncorrectables
1Locked256 QAM38405000000 Hz12.4 dBmV40.8 dB00
2Locked256 QAM1483000000 Hz12.3 dBmV40.8 dB00
3Locked256 QAM2489000000 Hz12.2 dBmV40.8 dB00
4Locked256 QAM3495000000 Hz12.1 dBmV40.8 dB00
5Locked256 QAM4501000000 Hz12.0 dBmV40.8 dB00
6Locked256 QAM5507000000 Hz12.0 dBmV40.9 dB00
7Locked256 QAM6513000000 Hz11.9 dBmV40.9 dB00
8Locked256 QAM7519000000 Hz11.9 dBmV41.1 dB00
9Locked256 QAM8525000000 Hz11.9 dBmV41.2 dB00
10Locked256 QAM9531000000 Hz11.8 dBmV41.2 dB00
11Locked256 QAM10537000000 Hz11.8 dBmV41.3 dB00
12Locked256 QAM11543000000 Hz11.6 dBmV41.3 dB00
13Locked256 QAM12549000000 Hz11.6 dBmV41.3 dB00
14Locked256 QAM13555000000 Hz11.6 dBmV41.3 dB00
15Locked256 QAM14561000000 Hz11.5 dBmV41.3 dB00
16Locked256 QAM15567000000 Hz11.5 dBmV41.7 dB00
17Locked256 QAM16573000000 Hz11.3 dBmV41.6 dB00
18Locked256 QAM17579000000 Hz11.4 dBmV41.7 dB00
19Locked256 QAM18585000000 Hz11.5 dBmV41.6 dB00
20Locked256 QAM19591000000 Hz11.4 dBmV41.7 dB00
21Locked256 QAM25459000000 Hz12.3 dBmV40.6 dB00
22Locked256 QAM34465000000 Hz12.2 dBmV40.7 dB00
23Locked256 QAM35471000000 Hz12.3 dBmV40.8 dB00
24Locked256 QAM36477000000 Hz12.3 dBmV40.8 dB00
25Locked256 QAM39411000000 Hz12.3 dBmV40.7 dB00
26Locked256 QAM40417000000 Hz12.3 dBmV40.7 dB00
27Locked256 QAM41423000000 Hz12.3 dBmV40.7 dB00
28Locked256 QAM42429000000 Hz12.4 dBmV40.7 dB00
29Locked256 QAM43435000000 Hz12.4 dBmV40.6 dB00
30Locked256 QAM44441000000 Hz12.2 dBmV40.5 dB00
31Locked256 QAM45453000000 Hz12.3 dBmV40.6 dB00
32Not LockedUnknown00 Hz0.0 dBmV0.0 dB00
Upstream Bonded Channels
Channel Lock Status US Channel Type Channel ID Symbol Rate Frequency Power
1LockedATDMA85120 Ksym/sec16400000 Hz35.0 dBmV
2LockedATDMA55120 Ksym/sec35600000 Hz36.0 dBmV
3LockedATDMA65120 Ksym/sec29200000 Hz36.0 dBmV
4LockedATDMA75120 Ksym/sec22800000 Hz35.8 dBmV
5LockedATDMA101280 Ksym/sec39600000 Hz41.8 dBmV
6Not LockedUnknown0000.0 dBmV
7Not LockedUnknown0000.0 dBmV
8Not LockedUnknown0000.0 dBmV
Downstream OFDM Channels
Channel Lock
Status
Modulation /
Profile ID
Channel
ID
Frequency Power SNR /
MER
Active Subcarrier
Number Range
Unerrored
Codewords
Correctable
Codewords
Uncorrectable
Codewords
1Locked0 ,1 ,2 ,337690000000 Hz13.28 dBmV41.6 dB1108 ~ 298776989044547425870
2Not Locked000 Hz0 dBmV0 dB0 ~ 4095000
Upstream OFDMA Channels
Channel Lock Status Modulation / Profile ID Channel ID Frequency Power
1Not Locked000 Hz0 dBmV
Message 1 of 11
Accepted Solutions
Guru
Re: CAX80: Poor Cable Connection Status
Your power levels are to high.
You need a 3-6db attenuator or a 3-4x splitter in line to get the power down a bit.
The power level should be between-7.5dbmv and 7.5dbmv. You're above 12.
Message 2 of 11
All Replies
Guru
Message 2 of 11
Kitsap
Master
Technically the power level is the responsibility of the ISP.  More frequently today, end users that own their own modems find the ISPs are less than responsive to requests for support.
@plemansrecommendation to add a splitter or attenuator to the line is action you can take.  If you do not have either of these items, they are available for a reasonable cost from Amazon.  If you use a splitter, be sure and buy caps to cap off any unused connections.  Make sure both the splitter and attenuator are specified for cable TV frequency range, usually up to 3 GHz.
Message 3 of 11
brownbear55
Guide
By using a coaxial splitter to slightly reduce the power, would I then see increased speeds or at least in theory?
Message 4 of 11
brownbear55
Guide
I used the Xfinity app and walked through the prompts for slow connection and using a variety of responses, Xfinity always places the responsibility of slow connection speeds on not themselves.
Message 5 of 11
Kitsap
Master
You are way too hung up on throughput (speed).
If your cable input signal power levels are not within specification, the modem will not have a chance to do the job it was designed to do.
Give your modem a chance to do it's job.  If you still have throughput problems, work your way downstream to find the problem.
Message 6 of 11
Kitsap
Master
Surprise!  Surprise!  NOT
Message 7 of 11
brownbear55
Guide
I placed an order for a 6db attenuator. It should be here within a week. I'll post results after I install it and run another diagnostic.
Message 8 of 11
Kitsap
Master
When the attenuator arrives, power down you modem before you connect it in line.  Then power up your modem and give it time to boot and stabilize.
Message 9 of 11
brownbear55
Guide
@plemans @Kitsap Thank you for your contributions and input! I installed the db attenuator (powered down the modem router first) and can confirm this $9 part I purchased from Amazon resolved the poor downstream status. And to think Xfinity wanted to charge me $100.
Here are the results:
Startup Procedure
Acquire Downstream Channel507 MHzLocked
SecurityEnabledBPI+
1Locked256 QAM5507000000 Hz6.1 dBmV41.1 dB00
2Locked256 QAM2489000000 Hz6.2 dBmV41.1 dB00
3Locked256 QAM3495000000 Hz6.0 dBmV41.1 dB00
4Locked256 QAM4501000000 Hz6.0 dBmV41.1 dB00
5Locked256 QAM6513000000 Hz6.0 dBmV41.2 dB00
6Locked256 QAM7519000000 Hz6.1 dBmV41.4 dB00
7Locked256 QAM8525000000 Hz6.1 dBmV41.4 dB00
8Locked256 QAM9531000000 Hz6.1 dBmV41.5 dB00
9Locked256 QAM10537000000 Hz6.0 dBmV41.5 dB00
10Locked256 QAM11543000000 Hz5.7 dBmV41.5 dB00
11Locked256 QAM12549000000 Hz5.7 dBmV41.5 dB00
12Locked256 QAM13555000000 Hz5.6 dBmV41.5 dB00
13Locked256 QAM14561000000 Hz5.6 dBmV41.5 dB00
14Locked256 QAM15567000000 Hz5.7 dBmV41.9 dB00
15Locked256 QAM16573000000 Hz5.5 dBmV41.8 dB00
16Locked256 QAM17579000000 Hz5.6 dBmV41.9 dB00
17Locked256 QAM18585000000 Hz5.7 dBmV41.8 dB00
18Locked256 QAM19591000000 Hz5.7 dBmV41.9 dB00
19Locked256 QAM20597000000 Hz5.8 dBmV42.0 dB00
20Locked256 QAM21603000000 Hz5.9 dBmV42.1 dB00
21Locked256 QAM22609000000 Hz5.9 dBmV42.2 dB00
22Locked256 QAM23615000000 Hz5.8 dBmV42.2 dB00
23Locked256 QAM24621000000 Hz5.9 dBmV42.2 dB00
24Locked256 QAM26627000000 Hz6.0 dBmV42.2 dB00
25Locked256 QAM27633000000 Hz6.1 dBmV42.3 dB00
26Locked256 QAM28639000000 Hz6.2 dBmV42.3 dB00
27Locked256 QAM29645000000 Hz6.3 dBmV42.4 dB00
28Locked256 QAM30651000000 Hz6.4 dBmV42.4 dB00
29Locked256 QAM31657000000 Hz6.6 dBmV42.4 dB00
30Locked256 QAM32663000000 Hz6.7 dBmV42.5 dB00
31Locked256 QAM33669000000 Hz6.7 dBmV42.5 dB00
1LockedATDMA65120 Ksym/sec29200000 Hz36.5 dBmV
2LockedATDMA55120 Ksym/sec35600000 Hz36.8 dBmV
3LockedATDMA75120 Ksym/sec22800000 Hz36.5 dBmV
4LockedATDMA85120 Ksym/sec16400000 Hz35.8 dBmV
5LockedATDMA101280 Ksym/sec39600000 Hz42.8 dBmV
Channel Lock
Status
Modulation /
Profile ID
Channel
ID
MER
Active Subcarrier
Number Range
Unerrored
Codewords
Correctable
Codewords
Uncorrectable
Codewords
1Locked0 ,1 ,2 ,337690000000 Hz7.48 dBmV41.7 dB1108 ~ 2987352858926180280
Message 10 of 11
Guru
Much more in line with what I'd expect or where it should be.
Hope it stays stable!
Message 11 of 11
Top Contributors
Discussion stats
  • 10 replies
  • 3195 views
  • 5 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
