- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
CM1000
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: CM1000
My cable-TV modem experience is minimal, but...
> Can I use my iPhone to setup my modem
Visit http://netgear.com/support , put in your model number, and look
for Documentation. Get the User Manual. Read. Look for "Install Your
Cable Modem and Connect It to a Computer". Clearly, the instructions
suggest using a wired connection from a computer directly to the modem.
If you read further, down to "Connect Your Cable Modem to a Router
After Installation and Activation", you may see:
During the installation and activation, you must connect the cable
modem directly to a computer. After installation and activation,
you can connect the cable modem to a router.
You could try connecting a wireless router to the modem before "the
installation and activation" are complete, and see what (if anything)
you can do at "http://192.168.100.1".
Alternatively, obtain (borrow/buy/rent/steal/...) a computer with an
Ethernet interface.
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
