- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
CM1000v2 Xfinity Gigspeed Issue
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi All,
I am having issues with my download speeds straight from the modem on my CM1000v2 device. I pay for the 1000mbps service but I am constantly only ever getting 600mbps down. I have an xfinity tech coming out tomorrow to check if the connection from the node to modem is the issue, but wondering if I provide the details from my modem here if anyone can help to identify any FW/SW issues. Thanks in advance for the help!
Modem: CM1000v2
FW version: V7.01.01
HW version: 2.02
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: CM1000v2 Xfinity Gigspeed Issue
Are you speed testing with a wired PC connected directly to the back of the modem?
Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Be sure to power OFF the modem for 1 minute them back ON.
https://community.netgear.com/t5/Cable-Modems-Routers/General-info-and-Troubleshooting-for-Cable-Mod...
- Mark as New
- Bookmark
- Subscribe
- Permalink
Are you speed testing with a wired PC connected directly to the back of the modem? - Yeah that is correct.
That is the plan.
None that I know of but will have the Tech confirm.
Will have to ask the tech about this as the line they setup a few years back was theirs.
Done multiple times with no luck.
Thanks @FURRYe38
- Mark as New
- Bookmark
- Subscribe
- Permalink
Ok, let us know how it goes...
- Mark as New
- Bookmark
- Subscribe
- Permalink
I am having the same issue. Called Xfinity and they mentioned issue with the modem. Called Netgear and they mentioned since more than 90 days need to buy $89 6 month tech support to get the software optimized. After purchasing $160 router getting shortchanged by Netgear like this. Expected better from them.
- Mark as New
- Bookmark
- Subscribe
- Permalink
The power levels might be a little high and why do you have so high a number of correctables?
If youv'e got a tech coming out have him look at your signal levels very closely.
