Orbi WiFi 7 RBE973
Reply
CM2050V needs daily power cycling
Chellen71
I've had this modem for about a week. I noticed right away that pages were taking a while to load and within a couple of days, I had to power cycle the modem because I had no connection. This happens at least every other day.
I have Xfinity voice, so I didn't have many choices for modems. I don't know if it's this particular modem or this model in general, that's problematic but is there anything that I can try to fix this issue?
My internet speed is 1Gig.
Message 1 of 7
Guru
Re: CM2050V needs daily power cycling
Please post a copy and paste of the modems connection status and event log page.
https://kb.netgear.com/30007/How-do-I-obtain-the-cable-connection-information-from-a-NETGEAR-cable-m...
https://kb.netgear.com/30008/How-do-I-view-or-clear-the-event-logs-on-my-NETGEAR-cable-modem-or-mode...
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
What is the brand and model of the host wifi router connected to the modem?
Message 2 of 7
Chellen71
Cable Connection
Cancel Apply
Frequency start Value
This field below allows you to modify the frequency the cable modem start with its scan during initialization and registration. Enter the new start frequency and restart the cable modem for it to take effect.
Starting Frequency
Startup Procedure
Downstream Bonded Channels
ChannelLock StatusModulationChannel IDFrequencyPowerSNRCorrectablesUncorrectables
1LockedQAM2564411000000 Hz-8.0 dBmV40.9 dB00
2LockedQAM2561393000000 Hz-7.7 dBmV41.3 dB00
3LockedQAM2562399000000 Hz-7.8 dBmV41.2 dB00
4LockedQAM2563405000000 Hz-8.1 dBmV41.0 dB00
5LockedQAM2565417000000 Hz-8.1 dBmV41.0 dB5351427
6LockedQAM2566423000000 Hz-8.4 dBmV40.8 dB00
7LockedQAM2567429000000 Hz-8.7 dBmV40.5 dB00
8LockedQAM2568435000000 Hz-9.1 dBmV40.2 dB00
9LockedQAM2569441000000 Hz-9.2 dBmV40.1 dB00
10LockedQAM25610447000000 Hz-9.1 dBmV40.2 dB00
11LockedQAM25611453000000 Hz-9.5 dBmV39.9 dB00
12LockedQAM25612459000000 Hz-9.7 dBmV39.7 dB00
13LockedQAM25613465000000 Hz-9.4 dBmV39.9 dB00
14LockedQAM25614471000000 Hz-9.3 dBmV40.0 dB00
15LockedQAM25615477000000 Hz-9.2 dBmV40.1 dB00
16LockedQAM25616483000000 Hz-9.2 dBmV40.0 dB00
17LockedQAM25617489000000 Hz-9.4 dBmV39.0 dB00
18LockedQAM25618495000000 Hz-9.1 dBmV39.6 dB00
19LockedQAM25619501000000 Hz-9.3 dBmV40.0 dB00
20LockedQAM25620507000000 Hz-9.7 dBmV39.7 dB00
21LockedQAM25621513000000 Hz-10.0 dBmV39.6 dB00
22LockedQAM25622519000000 Hz-10.4 dBmV39.1 dB00
23LockedQAM25623525000000 Hz-10.6 dBmV34.8 dB00
24LockedQAM25624531000000 Hz-10.8 dBmV38.6 dB00
25LockedQAM25625537000000 Hz-11.3 dBmV38.4 dB00
26LockedQAM25626543000000 Hz-11.5 dBmV38.2 dB00
27LockedQAM25627549000000 Hz-11.4 dBmV38.3 dB00
28LockedQAM25628555000000 Hz-11.2 dBmV35.4 dB00
29LockedQAM25629561000000 Hz-11.0 dBmV38.2 dB00
30LockedQAM25630567000000 Hz-10.9 dBmV35.5 dB00
31LockedQAM25631573000000 Hz-11.0 dBmV36.6 dB00
32LockedQAM25632579000000 Hz-10.8 dBmV37.9 dB00
Upstream Bonded Channels
ChannelLock StatusUS Channel TypeChannel IDSymbol RateFrequencyPower
1LockedATDMA1512016400000 Hz46.8 dBmV
2LockedATDMA2512022800000 Hz46.8 dBmV
3LockedATDMA3512029200000 Hz47.3 dBmV
4LockedATDMA4512035600000 Hz47.8 dBmV
5Not LockedUnknown000 Hz0.0 dBmV
6Not LockedUnknown000 Hz0.0 dBmV
7Not LockedUnknown000 Hz0.0 dBmV
8Not LockedUnknown000 Hz0.0 dBmV
Downstream OFDM Channels
ChannelLock StatusProfile IDChannel IDFrequencyPowerSNR / MERActive Subcarrier
Number Range
Unerrored
Codewords
Correctable
Codewords
Uncorrectable
Codewords
1Locked0 ,1 ,2 ,3193690000000 Hz-12.0 dBmV36.8 dB508 ~ 3587362195004361701622530
2Locked0 ,1 ,2 ,3194957000000 Hz-15.3 dBmV34.1 dB148 ~ 394737017901799678973267543483
Upstream OFDMA Channels
ChannelLock StatusModulation / Profile IDChannel IDFrequencyPower
1Not Locked000 Hz0 dBmV
2Not Locked000 Hz0 dBmV
Message 3 of 7
Chellen71
I am not using a router.
Hardware Version1.01
Cable Firmware VersionV2.01.03
Sun Sep 15 22:25:01 2024(Notice (6))CM-STATUS message sent. Event Type Code: 24; Chan ID: 193 194; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 2 3.;CM-MAC=08:36:c9:b7:84:d8;CMTS-MAC=00:90:f0:2c:01:00;CM-QOS=1.1;CM-VER=3.1;
Sun Sep 15 22:20:40 2024(Notice (6))CM-STATUS message sent. Event Type Code: 16; Chan ID: 194; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 2 3.;CM-MAC=08:36:c9:b7:84:d8;CMTS-MAC=00:90:f0:2c:01:00;CM-QOS=1.1;CM-VER=3.1;
Sun Sep 15 21:22:14 2024(Notice (6))CM-STATUS message sent. Event Type Code: 24; Chan ID: 193 194; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 2 3.;CM-MAC=08:36:c9:b7:84:d8;CMTS-MAC=00:90:f0:2c:01:00;CM-QOS=1.1;CM-VER=3.1;
Sun Sep 15 21:20:23 2024(Notice (6))CM-STATUS message sent. Event Type Code: 16; Chan ID: 194; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 2 3.;CM-MAC=08:36:c9:b7:84:d8;CMTS-MAC=00:90:f0:2c:01:00;CM-QOS=1.1;CM-VER=3.1;
Sun Sep 15 21:10:04 2024(Notice (6))CM-STATUS message sent. Event Type Code: 24; Chan ID: 193 194; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 2 3.;CM-MAC=08:36:c9:b7:84:d8;CMTS-MAC=00:90:f0:2c:01:00;CM-QOS=1.1;CM-VER=3.1;
Sun Sep 15 21:04:26 2024(Notice (6))CM-STATUS message sent. Event Type Code: 16; Chan ID: 194; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 2 3.;CM-MAC=08:36:c9:b7:84:d8;CMTS-MAC=00:90:f0:2c:01:00;CM-QOS=1.1;CM-VER=3.1;
Sun Sep 15 21:04:18 2024(Notice (6))CM-STATUS message sent. Event Type Code: 24; Chan ID: 193 194; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 2 3.;CM-MAC=08:36:c9:b7:84:d8;CMTS-MAC=00:90:f0:2c:01:00;CM-QOS=1.1;CM-VER=3.1;
Sun Sep 15 21:01:59 2024(Notice (6))CM-STATUS message sent. Event Type Code: 22; Chan ID: 194; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=08:36:c9:b7:84:d8;CMTS-MAC=00:90:f0:2c:01:00;CM-QOS=1.1;CM-VER=3.1;
Sun Sep 15 20:59:21 2024(Notice (6))CM-STATUS message sent. Event Type Code: 16; Chan ID: 194; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 2 3.;CM-MAC=08:36:c9:b7:84:d8;CMTS-MAC=00:90:f0:2c:01:00;CM-QOS=1.1;CM-VER=3.1;
Sun Sep 15 20:57:31 2024(Notice (6))CM-STATUS message sent. Event Type Code: 20; Chan ID: 194; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=08:36:c9:b7:84:d8;CMTS-MAC=00:90:f0:2c:01:00;CM-QOS=1.1;CM-VER=3.1;
Sun Sep 15 20:23:27 2024(Notice (6))CM-STATUS message sent. Event Type Code: 24; Chan ID: 193 194; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 2 3.;CM-MAC=08:36:c9:b7:84:d8;CMTS-MAC=00:90:f0:2c:01:00;CM-QOS=1.1;CM-VER=3.1;
Sun Sep 15 20:17:53 2024(Notice (6))CM-STATUS message sent. Event Type Code: 16; Chan ID: 194; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 2 3.;CM-MAC=08:36:c9:b7:84:d8;CMTS-MAC=00:90:f0:2c:01:00;CM-QOS=1.1;CM-VER=3.1;
Sun Sep 15 20:03:51 2024(Notice (6))CM-STATUS message sent. Event Type Code: 24; Chan ID: 193 194; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 2 3.;CM-MAC=08:36:c9:b7:84:d8;CMTS-MAC=00:90:f0:2c:01:00;CM-QOS=1.1;CM-VER=3.1;
Sun Sep 15 20:00:25 2024(Notice (6))CM-STATUS message sent. Event Type Code: 16; Chan ID: 194; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 2 3.;CM-MAC=08:36:c9:b7:84:d8;CMTS-MAC=00:90:f0:2c:01:00;CM-QOS=1.1;CM-VER=3.1;
Sun Sep 15 19:42:24 2024(Notice (6))CM-STATUS message sent. Event Type Code: 24; Chan ID: 193 194; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 2 3.;CM-MAC=08:36:c9:b7:84:d8;CMTS-MAC=00:90:f0:2c:01:00;CM-QOS=1.1;CM-VER=3.1;
Sun Sep 15 19:38:00 2024(Notice (6))CM-STATUS message sent. Event Type Code: 16; Chan ID: 194; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 2 3.;CM-MAC=08:36:c9:b7:84:d8;CMTS-MAC=00:90:f0:2c:01:00;CM-QOS=1.1;CM-VER=3.1;
Sun Sep 15 19:11:54 2024(Notice (6))CM-STATUS message sent. Event Type Code: 22; Chan ID: 194; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=08:36:c9:b7:84:d8;CMTS-MAC=00:90:f0:2c:01:00;CM-QOS=1.1;CM-VER=3.1;
Sun Sep 15 19:10:30 2024(Notice (6))CM-STATUS message sent. Event Type Code: 20; Chan ID: 194; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=08:36:c9:b7:84:d8;CMTS-MAC=00:90:f0:2c:01:00;CM-QOS=1.1;CM-VER=3.1;
Sun Sep 15 19:04:21 2024(Notice (6))CM-STATUS message sent. Event Type Code: 24; Chan ID: 193 194; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 2 3.;CM-MAC=08:36:c9:b7:84:d8;CMTS-MAC=00:90:f0:2c:01:00;CM-QOS=1.1;CM-VER=3.1;
Sun Sep 15 19:02:24 2024(Notice (6))CM-STATUS message sent. Event Type Code: 16; Chan ID: 194; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 2 3.;CM-MAC=08:36:c9:b7:84:d8;CMTS-MAC=00:90:f0:2c:01:00;CM-QOS=1.1;CM-VER=3.1;
Sun Sep 15 18:57:52 2024(Notice (6))CM-STATUS message sent. Event Type Code: 24; Chan ID: 193 194; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 2 3.;CM-MAC=08:36:c9:b7:84:d8;CMTS-MAC=00:90:f0:2c:01:00;CM-QOS=1.1;CM-VER=3.1;
Sun Sep 15 18:53:40 2024(Notice (6))CM-STATUS message sent. Event Type Code: 16; Chan ID: 194; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 2 3.;CM-MAC=08:36:c9:b7:84:d8;CMTS-MAC=00:90:f0:2c:01:00;CM-QOS=1.1;CM-VER=3.1;
Sun Sep 15 18:39:22 2024(Notice (6))CM-STATUS message sent. Event Type Code: 22; Chan ID: 194; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=08:36:c9:b7:84:d8;CMTS-MAC=00:90:f0:2c:01:00;CM-QOS=1.1;CM-VER=3.1;
Sun Sep 15 18:38:15 2024(Notice (6))CM-STATUS message sent. Event Type Code: 20; Chan ID: 194; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=08:36:c9:b7:84:d8;CMTS-MAC=00:90:f0:2c:01:00;CM-QOS=1.1;CM-VER=3.1;
Sun Sep 15 17:53:56 2024(Notice (6))CM-STATUS message sent. Event Type Code: 24; Chan ID: 193 194; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 2 3.;CM-MAC=08:36:c9:b7:84:d8;CMTS-MAC=00:90:f0:2c:01:00;CM-QOS=1.1;CM-VER=3.1;
Sun Sep 15 17:52:25 2024(Notice (6))CM-STATUS message sent. Event Type Code: 16; Chan ID: 194; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 2 3.;CM-MAC=08:36:c9:b7:84:d8;CMTS-MAC=00:90:f0:2c:01:00;CM-QOS=1.1;CM-VER=3.1;
Sun Sep 15 17:18:22 2024(Notice (6))CM-STATUS message sent. Event Type Code: 24; Chan ID: 193 194; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 2 3.;CM-MAC=08:36:c9:b7:84:d8;CMTS-MAC=00:90:f0:2c:01:00;CM-QOS=1.1;CM-VER=3.1;
Sun Sep 15 17:17:38 2024(Notice (6))CM-STATUS message sent. Event Type Code: 16; Chan ID: 193 194; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 3.;CM-MAC=08:36:c9:b7:84:d8;CMTS-MAC=00:90:f0:2c:01:00;CM-QOS=1.1;CM-VER=3.1;
Sun Sep 15 17:17:19 2024(Notice (6))CM-STATUS message sent. Event Type Code: 24; Chan ID: 194; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 2.;CM-MAC=08:36:c9:b7:84:d8;CMTS-MAC=00:90:f0:2c:01:00;CM-QOS=1.1;CM-VER=3.1;
Sun Sep 15 17:10:54 2024(Notice (6))CM-STATUS message sent. Event Type Code: 16; Chan ID: 194; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 2 3.;CM-MAC=08:36:c9:b7:84:d8;CMTS-MAC=00:90:f0:2c:01:00;CM-QOS=1.1;CM-VER=3.1;
Sun Sep 15 16:57:35 2024(Notice (6))CM-STATUS message sent. Event Type Code: 24; Chan ID: 194; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 2.;CM-MAC=08:36:c9:b7:84:d8;CMTS-MAC=00:90:f0:2c:01:00;CM-QOS=1.1;CM-VER=3.1;
Sun Sep 15 16:54:39 2024(Notice (6))CM-STATUS message sent. Event Type Code: 16; Chan ID: 194; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 2 3.;CM-MAC=08:36:c9:b7:84:d8;CMTS-MAC=00:90:f0:2c:01:00;CM-QOS=1.1;CM-VER=3.1;
Sun Sep 15 16:39:46 2024(Notice (6))CM-STATUS message sent. Event Type Code: 24; Chan ID: 194; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 2.;CM-MAC=08:36:c9:b7:84:d8;CMTS-MAC=00:90:f0:2c:01:00;CM-QOS=1.1;CM-VER=3.1;
Sun Sep 15 16:36:43 2024(Notice (6))CM-STATUS message sent. Event Type Code: 16; Chan ID: 194; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 2 3.;CM-MAC=08:36:c9:b7:84:d8;CMTS-MAC=00:90:f0:2c:01:00;CM-QOS=1.1;CM-VER=3.1;
Sun Sep 15 16:30:44 2024(Notice (6))CM-STATUS message sent. Event Type Code: 24; Chan ID: 194; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 2.;CM-MAC=08:36:c9:b7:84:d8;CMTS-MAC=00:90:f0:2c:01:00;CM-QOS=1.1;CM-VER=3.1;
Sun Sep 15 16:29:41 2024(Notice (6))CM-STATUS message sent. Event Type Code: 16; Chan ID: 194; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 2 3.;CM-MAC=08:36:c9:b7:84:d8;CMTS-MAC=00:90:f0:2c:01:00;CM-QOS=1.1;CM-VER=3.1;
Sun Sep 15 16:12:44 2024(Notice (6))CM-STATUS message sent. Event Type Code: 22; Chan ID: 194; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=08:36:c9:b7:84:d8;CMTS-MAC=00:90:f0:2c:01:00;CM-QOS=1.1;CM-VER=3.1;
Sun Sep 15 16:10:26 2024(Notice (6))CM-STATUS message sent. Event Type Code: 20; Chan ID: 194; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=08:36:c9:b7:84:d8;CMTS-MAC=00:90:f0:2c:01:00;CM-QOS=1.1;CM-VER=3.1;
Sun Sep 15 16:07:59 2024(Notice (6))CM-STATUS message sent. Event Type Code: 16; Chan ID: 194; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 2 3.;CM-MAC=08:36:c9:b7:84:d8;CMTS-MAC=00:90:f0:2c:01:00;CM-QOS=1.1;CM-VER=3.1;
Sun Sep 15 16:05:54 2024(Notice (6))CM-STATUS message sent. Event Type Code: 24; Chan ID: 194; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 2.;CM-MAC=08:36:c9:b7:84:d8;CMTS-MAC=00:90:f0:2c:01:00;CM-QOS=1.1;CM-VER=3.1;
Message 4 of 7
Guru
So just one PC connected to the back of the CM modem?
Power levels are too low:
https://kb.netgear.com/24311/Power-level-guidelines-for-a-NETGEAR-cable-modem-router
Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Start with removing any amplifiers, signal attenuators, or splitters from the coax.
From there check the line for kinks, damage, moisture in the line.
Check the connectors for improperly made ends, foil touching the copper coax line, loose connections, bad/old/cheap connectors, or corroded connections. Replace them if you do.
Be sure to power OFF the modem for 1 minute then back ON.
https://community.netgear.com/t5/Cable-Modems-Routers/General-info-and-Troubleshooting-for-Cable-Mod...
https://www.duckware.com/tech/solving-intermittent-cable-modem-issues.html
https://highspeed.tips/docsis-events/
Message 5 of 7
Chellen71
Yes, just a desktop. When you say power levels, what power levels, specifically?
Message 6 of 7
Kitsap
Master
See attached.
For reference see the first two sentences of this article:  https://kb.netgear.com/24311/Power-level-guidelines-for-a-NETGEAR-cable-modem-router
The ideal level is around +1 dBmV.  Normally the power level will vary no more than 4 or 5 (high to low) from the lowest frequency channel to the highest frequency channel.
Your values for the downstream bonded channels and the downstream OFDM are low.  If the power levels are low like yours, and you do not have any issues with the coax cable, the ISP will have to make adjustments at the street level connection.
Message 7 of 7
Top Contributors
Discussion stats
  • 6 replies
  • 760 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi 770 Series
