- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
How to get 1gb speed from Netgear C700 AC1900
- Mark as New
- Bookmark
- Subscribe
- Permalink
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Mikeberry3232 wrote:
I'm not sure what that means? This is my first time on here.
May be your first time, but you have 2 active subjects that are the same.
This one and https://community.netgear.com/t5/Cable-Modems-Routers/Get-1-gb-speed-from-Netgear-C700-AC1900/td-p/1...
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: How to get 1gb speed from Netgear C700 AC1900
While the any 24x8 device is capable of around ~960 Mbps PHY rate (approx 40 Mbps per channel times 24 channels), Comcast is *NOT* deploying 1 Gbps services on 24x8 modem.
Comcast is requiring all the customers to have Minimum of DOCSIS 3.1 devices for gigabit service.
Whenever you purchase a modem, you need to check compatability with your service plan on xfinity's website or call them.
https://mydeviceinfo.xfinity.com/
punch in your zip code and select service package you are using and it will show you compatible devices for that service level.
NTGR customer service would not be able to change how comcast deploys the service. I dont suggest to pay anything as there is no majic setting to make it work on Comcast gigabit. It will only work for max speed for which Comcast makes it compatible for.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Please STAY on one thread... multiple ones on the same problem just causes mixed results.
Use https://community.netgear.com/t5/Cable-Modems-Routers/Get-1-gb-speed-from-Netgear-C700-AC1900/m-p/16... please.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
comcast can provision maximum for 400 Mbps service on 24x8 devices.
you will not see gigabit speeds on DOCSIS 3.0 modems on Comcast.
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
